Question about Apple iPhone 4S
I dropped my iphone 4s-not from a great hight and the screen went black. how can I fix this please?
    New Friend:
  • 48 Answers
I would start by attaching it to your computer and seeing if the phone boots up.
If it doesn't there is not much you can do without taking the phone about. A used iPhone 4S can be had for under $100. You could also go with an iPhone 5/5s and get something a little newer without spending a lot either.
Posted on Jan 26, 2015
    Scholar:
    New Friend:
  • 115 Answers
If there is no apparent damage other than the screen now not coming on its possible that a connection inside may just have come loose. You can find many tutorials online about how to open up your iphone otherwise take it to a repairer who can take a look at for you. Without actually looking at it there isn't much else that I can suggest other than what has been said above.
Posted on Jan 27, 2015
    Problem Solver:
  • 12 Answers
Connect it to your computer to see if you aer able to access the phone at all. If yes, the screen is damaged. You can study some Videos on youtube to see how you could replace the screen. Good luck.
6ya staff
SOURCE:
My iphone 4s went completely blank black screen and it is not dead or powered off. i can hear it if it rings and it vibrates aswell. what can harm this to happen? is it old age?it is 5 years old.
water will have an affect on it if it has not been dried out properly the screen controller chip that is on the logic board will get damaged, =, they are not waterproof, you will need another logic board to repair this fault., can also damage the battery and the screen being in water for any amount of time.
Mar 10, 2015 | Apple iPhone 4S
My wifi wont turn on my iphone 4S why
common problem with iphone 4s. Means your wifi chip is disconnected from circuit board or defective. Some small iphone shops fix it by resoldering, but under some conditions it may happen again. High/low temperatures, drops and so on. If phone is still under warranty - apple will replace it free.
Sep 18, 2014 | Apple Iphone 4s latest Model - 16gb -...
My screen went black
this is happens whit i4 i4s after you drop the phone . you have to solutions . one if you know a technician hes gonna put back the flex of LCD witch removed after the drop its very easy or gonna change LCD & digitizer .
if your phone is not 4 or 4s you have to change the lcd digityzer for sure .
Mar 02, 2014 | Apple iPhone 5c
Phone display
Did you drop it or get it wet? If the screen just went out then a simple replacement may fix the issue. iPhone 4S repair and replacement parts
Feb 17, 2014 | Apple Iphone 4s I Phone 4 S Factory...
I dropped my iPhone 4S outside on my porch, but It was in a lifeproof case. It worked fine after, but an hour later, the phone screen went BLACK. I can still feel it vibrating, but i cant use it because...
One of the internal connections likely broke or came loose. Did you take it to an Apple store? They should be able to diagnose it and tell you what it will take to fix it.
Aug 06, 2013 | Cell Phones
Xperia hang
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPhone 4S will erase everything on it, so make sure everything on the iPhone 4S is stored elsewhere prior to restoring. To restore, connect your iPhone 4S to a computer with iTunes installed. Click "Restore" on the iPhone 4S summary page (click on your iPhone icon on the left menu to find this page). Follow the directions to restore. If your iPhone 4S displays the text "Please wait. Very Low Battery," leave it plugged in. This charges the iPhone 4S enough to be able to restore. If the iPhone 4S hangs on this screen for long periods of time, you may need a new battery.
Force restore mode
If your iPhone 4S is hanging with an Apple logo, or exhibiting some other software problem that prevents iTunes from recognizing it, you can force it into recovery/restore mode and then use iTunes to restore the software.
If the device is powered off, plug one end of your USB cable into the iPhone 4S and leave the other end disconnected. Press down on the Home button, and keep holding it down while you plug the USB cable into your computer. After 5-10 seconds, you should see a "Please Connect to iTunes" image on the iPhone 4S, and iTunes should prompt you to restore the software; follow the prompts and the instructions given above.
If the device is powered on, hold down both the power and home buttons until the device reboots and displays the "Connect to iTunes" image (generally, 5-15 seconds).
God bless you
Jun 01, 2013 | Sony 1270-9121 - Xperia Z C6602 5in 16gb...
I dropped my Iphone 4s on the floor. The screen went black, and wont turn on. When i connect it to the charger is does not do anything. When i connect it to my Itunes it wont regonize it. what do i do?
I suggest you take your broken Iphone to a cell phone repair shop.
Get a quote for the repair then you can decide whether to go ahead with the repair or get a new Iphone.
Jan 28, 2013 | Apple iPhone 4S
I dropped my model No. A1241 phone and the touch screen doesn't work but it has no cracks. how can I fix it?
not having a crack on the screen doesnt mean your touchscreen will work. you said you drop your phone, it has a great possibility that it cause an internal damage to some of the microchip inside your phone that controls the sensors of your touchscreen.need to reheat the microchip inside it. open your phone and try to check for the microchip near the flex from the board of your phone going to your screen. then reheat it, but dont move it.
Jul 10, 2011 | Skque SILICONE SKIN CASE FOR APPLE iPHONE...
Apple iPhone 4S Logo
90 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
Travis
Travis
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
