Brother Dcp-7055 Laser Print Copy Scan 2400 X 600 Dpi Scan 20 P Logo
s
samantha bell Posted on Jan 25, 2015
Brother dcp-7055 self diagnostic
My printer says self diagnostic, then unable to print any ideas how to fix?
KR Aggarwal
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jan 27, 2015
KR Aggarwal
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
2919
Points
13
Go to the Maintenance Mode by pressing Pressing "Menu, *, 2, 8, 6, 4". If you done it correctly, the printer will beep, lights will flash and the control panel will read Maintenance.
After it Press 9,9 and it will reboot and start its normal reset procedure.
If it still not work, then there may be the problem with fuser or main board. Check both one-by-one. This may solve the problem.
2 Related Answers
dawahyolmo33
dawa lama
  • Posted on Apr 06, 2014
SOURCE: i have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
tomidbsimcha
  • Posted on Aug 21, 2014
SOURCE: how can solve deam print quality in dcp-7055 printer
? I didn't understand your question
How to solution printer unable 71
https://www.manualslib.com/manual/794794/Brother-Dcp-7055.html?page=81
I am tired and fed up from the problems appeared on the screen of Dcp 7055 that Print Unable EF
https://www.manualslib.com/manual/794794/Brother-Dcp-7055.html?page=106
Brother DCP 7055 Service Manual Error Code Ee ef
Quoting from the free manual Page 2-69:
? Error code EF
Print Unable EF
Turn the power off and then back on again.
The supplied power is unstable.
Step
The irregular power supply is
detected
Main PCB failure
Note:
• The irregular power supply detection error (Machine Error EF) occurs when there is a
large fluctuation in the power supply voltage supplied to the machine.
In this case, if the same power supply is used, the same error might occur again even if
the low voltage power supply PCB ASSY is replaced.
Unable to print 36
Possible Reason:
1. High voltage power supply PCB
failure
---Replace the high voltage power supply
PCB ASSY.
2. Harness connection failure of high
---Check the harness connection of the high
voltage power supply PCB and reconnect
it.
3. Main PCB failure
---Replace the main PCB ASSY.
2helpful
Printer show Print unable EF
Re-install your printer's driver in your PC or Laptop.. then try to print the Demo Page..
#NZ
86helpful
5answers
I have brother DCP 7055 it shows print unable 71 error pls suggest
162helpful
7answers
MY BROTHER PRINTER DCP-7055 EORRER REPLACE TONER
This came from the Brother HelpDesk, yes they rang me and it worked.
Cover open Press Clear "Replace Drum?" (ignore this and quickly...) Press Start (blank screen, quickly...) Press Up arrows then switch to down arrow to 00 Press OK
80helpful
4answers
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Norman Weimar
Norman Weimar
k24674
