Simple. Load the Apple System start-up disc first while the computer is running. You should see its icon on on the screen. Then select restart from the Apple Menu on the top left of the screen. Hold down the C key as it reboots. You will now boot into the start-up disc. This method also applies to Disc Warrior and other tools. Alternately, with the computer already running, insert the Apple System start-up disc then go to System Preferences also under the Apple menu, Under the start-up disc icon, select your apple system icon and restart.
Third alternative. With the computer running insert Apple System start-up disc. Restart the computer. Before the chime, press and hold the option key, left-hand bottom side of the keyboard to the left of the Apple (Command) key. You will see your system HD icon and the screen as well as your Apple System disc. Click on the System Disc and that will boot the machine.
Press the Media Eject key at the top-right corner of the keyboard.
If that doesn't work, drag the disc's icon to the Trash.
If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected. To restart, choose Restart from the Apple menu.
font.f1 {font: 12.0px Helvetica}
Thanks for asking your question with Fixya Support. I will be glad to assist you.
Try running a Disk Repair with Disk Utility using your Mac OS X installation disc or restore disc (which came with your Macbook)
font.f1 {font: 13.0px 'Myriad Pro'}
-RUN DISK UTILITY WITH STARTUP DISK-
Insert your Mac OS X Startup disk •Reboot your Mac •At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear. • Release the C key only after you see the Spinning gear. •Mac will boot from the startup disk to the Installer environment • From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application. • Click on on the hard drive at the top of the window in the left sidebar and • Select "Repair Disk" **Let Disk Utilities run this repair the disk until completion • At the end of this process, reboot your Mac
See if that process helps bring your Macbook up to the normal desktop.
If it does not, use the SMC reset procedure.
-SMC RESET- The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
• If the computer is on, turn it off. • Disconnect the AC adapter and remove the computer's battery. • Press and hold the power button for 5 seconds and then release the button. • Reconnect the battery and AC Adapter. • Press the power button to restart the computer
This should help resolve the issue for you. If it does not however, just let me know.
Option 1: If you restart the computer and just after it restarts if you hold down
the eject key on the keyboard it should eject the disc, if not I would
check to see if there is a tiny hole on the disc drive that you can
stick a paper clip in - not sure if the ibook will have it but worth
while checking.
Option 2:
1. Restart the computer.
2. Immediately after the startup sound, press and hold the key
combination Command-Option-O-F.
Note: The Command key has the Apple icon on it.
3. Release the keys when you see a white screen that says "Welcome to
Open Firmware."
4. At the prompt, type: eject cd
5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the
action is complete.
6. Type: mac-boot
7. Press Return.
Load gray disc 1 and then shut down computer. Power back up and press option key. Select the start up disc and press enter or the right icon arrow key. Wait for the thing to load. Then at the top select the Disk Utility and then select your hard drive at the left panel. Then select the button that says repair disk permissions. Then select the button that says repair disk. After that restart the computer using the hard drive and not the disk.
Next step is this tedious process is shut down computer. Now press power button and immediately press at the same time the option key, and the apple icon key next to it, and the letter P and the letter R. Now wait until you hear 3 bong sounds from the speakers and then you can let go.
Next step is to select system preferences, select accounts, select your account, select login in items and select everything in the box. Now press the - icon to remove them. Don't stress your not removing the actual programs. Your just telling the laptop not to load them upon startup.
Next step, you need to go into disk utilities and partition the hard drive into 2 sections. 1 section will load Mac OS X and the other section will load Windows 7.
Finally, you should remove your RAM and re-seat them as sometimes that causes long startups. Also, check the about my mac to make sure both RAM chips are recognized and working. Also, upgrade to the max RAM allowable to speed up startup times and upgrade to 7200 RPM hard drive instead of your 5400 RPM.
To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
Click the iTunes eject button (see Figure 1).
Hold down the mouse button when you hear the startup sound as the computer restarts.
Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
Press the Eject key on the Apple Pro Keyboard.
If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
Click the eject button in iTunes (illustrated in Figure 1).
Start up from Mac OS 9.2 and follow the options in the section above.
This wil show you how to take it apart if that becomes necessary. But try this instead. First hold the eject button down for 5 seconds. I that fails look for a tiny hole near the disc slot. Use a straightened paper clip and push it in the hole firmly. This should eject the disc. Another option is to use firmware to eject the disc. Follow these directions:
To eject a disc with Open Firmware commands, follow these steps:
Immediately after the startup sound, press and hold the key combination Command-Option-O-F. Note: The Command key has the Apple and () icons on it.
Release the keys when you see a white screen that says "Welcome to Open Firmware."
Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
The computer is saying that it cannot find the operating system. Usually, due to hard drive broken or you got corrupt boot up files. Insert disc 1 Apple gave you then turn the thing off. Now turn the thing back on and hold and press the option key on your keyboard. Release the key when the disc loads. Select the icon of the disc and press the right arrow. Then when the disc loads, you can go select utilites and then select disc utilities. Then select your hard drive in the left top box and then select First Aid and then select Repair Disk permissions. Close out and quit and try pressing the power button again. Also, try deleting the startup programs by going to system preferences, accounts, and login items. Then click on all the programs and click delete. Sometimes these crazy startup programs interfere with the bootup. If that don't help, then you def need a new hard drive.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Reastart the iMac and at the same time hold down the mouse left click button. If that does not work.
