Lands Phones Logo
Leon Ravich Posted on Jan 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Telephone Jack) The Telephone services provider make record of the messages. I'd like to record my massages to my answering machine. I'll appreciate your suggestion Thank you.
Joseph Wright
Level 3:
  • Master 1,729 Answers
  • Posted on Jan 25, 2015
Joseph Wright
Master
Level 3:
Answers
1729
Questions
Helped
454956
Points
5127
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
3helpful
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 6 Answering System On
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
0 then 9 Answer System Off
1 then 0 Help Guidance
Command Function
0 then 1 Repeat a Message*
0 then 2 Playing incoming Messages
0 then 3 Skipping a Message
0 then 4 Deleting a Message
0 then 5 Stop Operation
* For Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
** For Memo Record and Greeting Message Record function, the first time you enter
the corresponding command, it starts the Recording function. If you want to stop
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
How do I access messages when I am not by the phone?
nschutz,
Remote Operation
You can operate your answering system from a remote location (when you are away from home, or from another room using a handset).
Use this function to check for recorded messages, to play or delete message. When using any touch-tone telephone, you can even record a new greeting message.
Remote Access away from Home
You can operate your answering system from a remote location using any touch-tone telephone.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code
3) The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
*For Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, enter the command again.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering system automatically returns to standby.
0 then 2 Play Incoming Messages
0 then 7 Memo Record/Stop*
0 then 3 Skip a Message
0 then 8 Greeting Message Record/Stop*
0 then 4 Delete a Message 0 then 9 Answering System Off
1 then 0 Voice Prompts
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the number of messages stored in memory. You hear "To play incoming messages, press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system on. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Respectfully,
Adam04
I have a Uniden cordless answer machine,Can my meesages be retived?
You can operate your answering system from a remote location using any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even to record a new greeting message.
  1. Call your telephone number.
  2. During the greeting message, press 0 and enter your PIN code. By default, the pin code is "80" without the quotes.
  3. The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two. For help, press one zero".
Available commands are:
  • 0 then 1 Repeat a Message
  • 0 then 2 Playing Incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop*
  • 0 then 8 Greeting Message Record/Stop*
  • 0 then 9 Answer System Off
  • 1 then 0 Help Guidance
1helpful
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
I have a code for my Uniden cordless to get voice mail while away from home. Not sure what else I need beside the code.
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
handset). Additionally, you can turn on or off your answering system remotely.
You can operate your answering system from a remote location using any touchtone
telephone.
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
stored in memory. You hear "To play incoming messages, press zero-two. For
help, press one-zero." You will hear a beep.
* For the Repeat a Message function, press 0 then 1 within about four seconds to
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
stop the recording, press 0 then 7, 8 or 5.
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
1helpful
Retrieving message
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
2) During the greeting message, press 0 and enter your PIN code.
Command Function
If you forgot to turn on answering system the directions for that are here:
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
How do I retrieve my voice mail when I'm away from home?
this instruction may help you , if not a model number could help , but try these instructions . thanks
To operate from a remote location, use any touch-tone telephone, and follow these steps:
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 57).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following chart:
Remote Commands
Command 0 then 1
Repeat a Message*
Command 0 then 6
Command 0 then 2
Playback Messages
Command 0 then 7
Memo Record/Stop**
Command 0 then 3
Skipping a Message
Command 0 then 8
Greeting Record/Stop**
Command 0 then 4
Deleting a Message
Command 0 then 9
Answer Machine Off
Command 0 then 5
Stop Operation
Command 1 then 0
Help Guidance
we can get a link to your manual if we had model number
Picking up messages remotely
Try this...
Remote Operation
Command Function
4helpful
Checking voice mail remotely
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
Additionally, you can turn On or Off your answering system remotely.
1) Call your telephone number and wait for the system to answer. If the answering system is
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
4) Enter a command within 15 seconds, each command there after must be entered within 2
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
5) After the command has finished, you hear intermittent beeps indicating that the system
chart above.
returns to standby.
37helpful
2answers
Uniden answering machine model 900MHZ
Here is a link to the pdf format owners manual from Uniden for this phone:
http://www.uniden.com/pdf/TRU8885om.pdf
Remote Operation
telephone.
on page 25).
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
