Connected Chromecast and 1 month later lost picturee Reconnected Chromecast and 1 hour later lost sound on Samsung TV. Could there be a connection?
It won't damage the TV. Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Type in the brand name of your device, in the search box at the display window, and press enter to get all related posts. It will make surf easy.
Thank you Knight. I will keep trying. I have no picture and no sound now, and I found all this a bit overwhelming. When I get the courage, I will try to open the back panel. How do I know if the back light inverter board is damaged? Someone also mentioned that some capacitors or fuses may be blown/burned.
Whatever suggestions you've got, it will be best to replace the defective board as card basis, rather than making surgery to it. In most cases, it will be a failure. I'm doing this kind of work; I mean, service and repair work to all kind of electronic equipment; since 1974; and doing the same till now. From the work experience I've got from these long 43 years, I suggest you to replace as card basis. But, before replace the card, you should detect which board is faulty. That will be a problem, and is the main part of any repair work. You too will admit it.
anyway, try to detect the faulty board. Then determine what to do. What else to say.
