Toshiba, 15lv505 Completely digital ready, ATCS, QAM the antenna is a GE amplified digital antenna - all both relatively new and yes, I have tried scanning numerous times.Toshiba, 15lv505
You can't post conmments that contain an email address.
All plasma TVs are able to pick up local stations without any other accessories. Hook your antenna to the 75 ohm cable input go to menu and select channel search and it will find and store any active channels you can receive...its quite easy to set up
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You need to upgrade to the high definition
cable box---but first try this. Hook the cable from the wall directly to the tv
and autoprogram it. If Comcast is anything like charter they transmit the local
Hd channels in a format that digital tuner will pick them up. Just channel
up/down and check out the channels with -1 and -2's behind them. Depending on
where you are----your local channels will usually show up wherever they
normally do but with a -1 behind it.
EX: local Fox channel on 47---autoprogram and check 47-1
If this is enough HD for you then get a two way spitter and hook your box back
up and keep using the RCA (composite) cables for the best it can produce.
If your TV was made after 2007 it should have the digital receiver built in. If so you can just hook any antenna you wish up and receive all your local channels.
You may be looking in the wrong place or have the wrong kind of antenna. With the digital conversion, TV channels shifted from the numbers they used before. In my area, the previous Channel 6 is now broadcasting in the UHF band.
It can be harder to adjust the antenna for a digital TV because it is either working well or totally off - no gradually decreasing "snow" as a clue.
It is possible your TV is not equipped to pick up digital TV. There are converters to translate digital TV to analog signals for older TV. They cost between $30 and $70 depending on features.
Are you positive that your city has not done the Digital Conversion? Some Cities are doing it early before the February deadline. Also make sure you are tuning in to the correct channels. Meaning that if on your Cable Provider ABC was on Channel 3 that does not mean that ABC with still be on Channel 3 after you have your Cable turned off. Most of the Time the Local Stations Tag will let you know what channel its on. It will be something like "KWAS ABC 27" So on your TV you would Tune it to channel 27 to get ABC and the same fore NBC , FOX, CBS , etc... I hope this helps Take Care =)
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
Toshiba, 15lv505
