Hi, do you speak spanish? I have a treadmill xterra3.0 but when i was assembled to use it...it marks error 6 . What it could be.... I have contact the proveedor and they send me the master card ( idont know if that its called) but still doesnt works. Please help me. When i turn it on , marks to press strat and then it sounds like if its going to works but its not....
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Dear Sir:
1) Tight the deck belt see the diagram 2) Lube the deck belt in according with the instruction manual maintenance. 3) Test the drive belt and replace it 4) Measure the input voltage for the main motor if there are the motor need repair or replace 5) Test the output voltage from the main motor board if there are NOT the board is faulty.
SOURCE: GE3100T treadmill stopped working
HI,
All the treadmills have a power switch with Auto reset. If there s any overload detected it will automatically reset to off position To prevent any further damages. Just check the power switch of the treadmill. If its it off position then turn it one and check the treadmill. If the switch again rest to off position then try to call for a tech to repair the treadmill.
Ajin
SOURCE: Treadmill E1 Error
Version:1.0
StartHTML:0000000168
EndHTML:0000001348
StartFragment:0000000468
EndFragment:0000001331
ERR1
indicates a speed issue. In this case, the motor speed as reported
from the optic sensor differs from
the speed setting. Analysis:
Optic sensor signal issue -- Either the optic sensor signal is not
right, or it is read incorrectly, or the
signal is not reaching the display. clean the speed sensor, test for open or faulty. tight the connector very well. RUN the software calibration for easy troubleshooting and fix it. see the diagram attached. and follow steps. God bless you The
Steps for Newer Style Console Calibration Locate the calibration area on the
rear or underside of the console (a hole, near the console's center,
that goes through to the electronics board. (This hole should not
have a screw in it.) Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click
when pressed). Press the button 2 times
(with the pencil eraser). The first click should show CL11
in the console, the second click should show CL21. If the process was done correctly,
and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons
on the console and observing settings. This will not require
any other tools. Press ENTER. CL22 should display
in the TIME window and (??) in the SPEED window. Press ENTER. CL23 should display
in the TIME window and (??) in the SPEED window. Press ENTER. CL24 should display
in the TIME window and (??) in the SPEED window. Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window. Press ENTER. CL26 should
display in the TIME window. You should then see the
letter "E."
Press ENTER. You should see "SS"
or "55" in the console.
Push the STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill. Push the ENTER button. The walking
belt should start to move, accelerate to maximum speed, then stop on
its own.
When the belt stops, the
incline should self test by raising to its highest
incline position, then lowering back down to its lowest
position. Once the incline test is complete,
push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
Version:1.0
EndHTML:0000003648
EndFragment:0000003631
