Watches Logo
r
rashid hussain Posted on Jan 22, 2015
How can i come to know about the selling period of rado diastar?
Please tell me the selling time and place of this watch?
Asha Goyal
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 28, 2019
Asha Goyal
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
211
Points
Clara Morgan
Level 1:
New Friend:
  • Posted on Sep 01, 2016
Clara Morgan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
211
Points
I bought watch from online website mirraw check it out here
http://www.mirraw.com/store/watches
5 Related Answers
Anonymous
  • Posted on Nov 27, 2008
SOURCE: I have a Rado DiaStar
Hears how i do my watch, i have the same watch as you.Just make sure nothing is displayed on the clock face by turning the winder, ie NO digital time, NO daul time, NO alarm, NO stop watch etc, Pull out the winder(crown) and adjust the hands to the time you require by spinning the winder.(Gentley for mins and fast for hours) The digital clock will display wilst doing this, but not change the time.handy if you want to sync both clocks.Push the winder back in at the time to sync and the digital display will go out, then spin the winder again if you want to display the digital features. I hope this helps, please post if it does, Maurice Chevalier- Herts
Anonymous
  • Posted on Jan 06, 2009
SOURCE: Rado Watch
I brought mine online from http://www.ernestjones.co.uk/webstore/browse/N/65+4294967253
You are better off getting your watch from a credible supplier like Ernest Jones as they come with a guarantee..
Anonymous
  • Posted on Dec 06, 2009
SOURCE: rado diastar swiss 196-0364-3
I bought the same watch recently and have the same problem. The hours can be adjusted in the dual time zone by looking up the manual, but the minutes stay put. I can't bring them to blink so that these could be adjusted. Any ideas? I sent a mail to Rado through their website but no answer.
Anonymous
  • 98 Answers
  • Posted on Jan 16, 2010
SOURCE: how to reduce size on a Rado Diastar wrist watch
That links are most likely ceramic! Take your watch to a reputable watch repair shop...they break very EASY! Make sure they know what they are doing!!!!
Azrael SRL
  • 11800 Answers
  • Posted on Jul 13, 2011
SOURCE: Looking for Rado Diastar Anatom watch bracelet
The only source for separate original links is a repair shop that has a defective watch kept for parts. You could order an entire bracelet but that would be very expensive.
The cheapest solution is to get a copy like
http://www.flyingshops.com/rado-anatom-mens-watch-r10365151-4796-p.html
and use its bracelet.
1helpful
What's the price of this watch rado diastar
hi the watch i found is pretty much identical. only thing is anchor is at different angle. points straight down not to the right and its a females watch. price is bout 506 pounds or 895 dollars. hope this is useful to u.
Jan 21, 2013 • Watches
Hi, The first link on my Rado Strap has chipped. Can I get the link replaced without having to replace the whole strap.
Just go to your local service center found on www.rado.com and they will replace the link for you for about $25.
1helpful
2answers
How do i set time and date of my rado wristewhatch?
Hi - I have a Rado Jubilee-Black Face-Lovely Dial
Problem:Time is set with a Key - Back of the watch
I have LOST this Key & need to buy or get one?
Can you please advise - [email protected]
Many Thanks
Ms>Mohamed
The release buttons on the clasp of my Rado Jubile wrist watch have lost their spring tension can it be fixed
mcdevito75 here, Best Bet with your Rado watch, Look for a small watch repair shop in your area for adjustment / replacement.
1helpful
Rado watch stopped working
It sound like a fault. Be careful who looks at it though and what they charge - a complete new quartz movement for most watches, even fancy ones like your don't cost as much as £90 so almost all of what you are charged is labour.
9helpful
Watch stopped after not being used for several days
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch).
As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly.
(Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually.
Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops.
If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out.
Do not forget to rate, please.
Rado diastar swiss 196-0364-3
11helpful
I have a Rado DiaStar watch (with digital display), and the hands are out of synch with the digital display. Is there a way of adjusting the hands independently of the display? or must it be sent back to...
Top Rado Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Rado Watch Expert? Answer questions, earn points and help others
