To save caller ID with a name in Panasonic KX-AT7730, you need to follow these steps:
Press the "Program" button on the phone.
Dial "9" to enter the "Caller ID" setting.
Dial "1" to enter the "Caller ID Memory" setting.
Dial the memory location number (0-99) where you want to save the caller ID and name.
Enter the caller's phone number using the keypad.
Press the "#" button to move to the next field.
Enter the caller's name using the keypad (use the alphanumeric keys to enter letters).
Press the "#" button again to save the entry.
Repeat steps 4-8 for each caller ID you want to save.
Note: Caller ID service must be enabled on your phone line for this feature to work. Also, make sure you have enough memory locations available in your phone's memory to save new caller IDs.
According to the manual, the RCA 25413 does not support Caller ID. I have provided a link where you can download the manual. The manual is for model numbers 25413 and 25414. On page 8 it details how to turn caller ID on/off for each line under Ringer Tone heading item 6 Note, but the note says it does not apply for model 25413. Hope this helps.
Hi, Try connecting your phone to some other phone lines in which the caller id is working properly and this way you can check if the problem is with your device or line.
For all the phones to display the caller information properly, CLID (caller line identification service) should be enabled for your landline connection. Please contact your phone line provider to enable this service and you should be able to see the caller id information in your panasonic device.
I hope this is helpful to you thanks Please rate the solution
Unusual problem. Check the settings to make sure theirs not a way to disable Caller ID. Give Verizon a call and see if they can find out whats going on.
Yes, I re-read the manual and it says (under Caller ID) to press the flash/program button to answer the new incoming call...I must have hit the pound key in error thinking I hit the flash button. I have yet to try this in real time, but will next time it arises and report if it does NOT work.
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
I am making the assumption that only line 1 has caller-ID. Both of my suggestions require services on the phone lines themselves, and not thru the phone system.
Line 1 needs features on the line to allow three-way calling. Then you would hit the Recall key after answering to send a Flash to the Central Office to dial the 2nd number. This takes the transfer away from the phone system and puts it on the CO. This requires more time and effort on the staff answering phones, and if a calls comes in while this is in progress, it's going to roll over to another number in the hunt sequence anyway.
I have the same problem with my unit. Emerson customer service made some suggestions, including pulling the 9V battery, disconnecting the phone from phone and power for 3 hours, etc.
Their first suggestion (earlier this morning) was to Push "Up" button and hold for 4 seconds, then pressing the "delete" button three times and re-pressing the "Up" button for 6 seconds.
That procedure failed.
I'm in the midst of the 3 hour wait after full disconnect of phone line and 120V plug.
I don't think my phone will come back. I'll be happy if it does.
Good luck with yours...Richard
