Mitsubishi WD-60735 Compatible TV Lamp Logo
b
bob parker Posted on Jan 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced projector lamp and my lamp light still blinks
Replaced new lamp lamp light still blinks
Terry Dovre
Level 2:
  • Expert 195 Answers
  • Posted on Jan 31, 2015
Terry Dovre
Expert
Level 2:
Answers
195
Questions
0
Helped
27022
Points
406
Hello, make sure that all the covers are on properly, was the old lamp broken? If it wasn't it may have not been the problem, sometimes the ballast board will cause the lamp light to blink like the lamp is bad....tks
I have a epson tw1000 projector i bought and i ordered two new lamps off of amazon got the lamps put one in the projector flipped the power switch on on the back of the projector light turns orange to let...
Lamp ballast is not work , you can replace a new ballast or to repair it.
Have a good day!
Jerry China
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
7helpful
3answers
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
1helpful
New lamp is placed in tv, but tv won't come on. Light in front of power button is blinking green, then blinks red. Not sure what the problem is
One question, why you decided to replace lamp in tv? Did tv showed red lamp light blinking?
Suggestion, make sure lamp cover has been placed back in its position after lamp replacement, lamp cover is first thing that you removed from tv cabinet to take out lamp.
Lamp burned out on X1 infocus projector, Replaced lamp, new lamp stopped working in about 5 hours, got another new lamp and it does not light at all. Still blinking 3 red blinks(saying the bulb is bad)
make sure the colorwheel is spinning. if it is not, replace it. also, blow the dust out of it with canned air. excessive dust kills lamps quickly. you'll also need to reset the lamp timer. are you using an sp-lamp-009? the sp-lamp-018 looks exactly like it, but is used in th x1a and x2. the x1 only uses the sp-lamp-009. if all else fails, replace the power supply.
3helpful
2answers
Blinking red light
replce lamp ballast board of your projector...
Alternating power and lamp status lights
...replace the lamp. The lamp is most likely WAYYYYY past its prime so I suggest starting there. Sometimes even if you had just replaced the lamp the new lamp could've blown. When there is no signal running through the lamp circuit there is no signal to the display sensor, which means no image.
hope this helps!
5answers
Blinking bulb light
Hi there
You must always reset the lamp timer when replacing a bulb.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
