Washing Machines Logo
Andre Lef Posted on Jan 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OIL STAIN ON A CLOTHES out of washing machine E12477
It's been a few times a piece of clothes is stain with black oil. Other pieces are OK - Please?
Julie Clark
Level 2:
Sergeant:
  • Expert 266 Answers
  • Posted on Jan 20, 2015
Julie Clark
Expert
Level 2:
Sergeant:
Answers
266
Questions
0
Helped
79560
Points
606
Are they getting the oil stain from the washing machine? If so, you need to get a tech out to inspect your washing machine. If you are putting oily clothes into the washing machine hoping it will come out, it's too late, you need to pre-wash with Shout or Tide to remove oils and grease. The more you wash and dry it the deeper the stain will set. Sounds like you need to throw those clothes away.
My LG Front Load washing machine is leaving black streaks and smudges on my clothing. These streaks and smudges are ruining my clothes!
There can be several things that can cause this problem. The most common are:
1. Fabric softener - did you switch brands lately?
2. Chlorine bleach - if added at the wrong time
3. A mechanical problem with the washer, like a leaky transmission leaking oil.
4. Rust staining, sometimes caused by the water being used in the machine.
Here is a link to a site that discusses this issue more in depth:
http://www.stain-removal-101.com/washing-machine-stains.html
tip
How to remove oil stain from clothes
Immediately apply water on stain and try to absorb oil from the cloth using tissue paper. Once you are home, take a lemon, squeeze the juice on the stain, keep it aside for 30-45 minutes. Next apply detergent powder on the stain and rub gently, wash with water. The stain will get faded. now soak the cloth in soap and water for 1 hour and wash gently. After one or two wash the stain will go completely.
on Nov 05, 2018 • Miscellaneous
My washing machine is in a working condition but why the clothers are not properly wash and some kind of brown or black stain apeared. Even when white clothes are separetly washed. Is there any help can...
this could be Drum bearings gone if its oil in clothes, Is it very noisy during spin if so then Bearings, quite an expensive repair......Not always worthwhile...
2helpful
Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
I am getting oil like stains on my dark clothes that are not on them when they go in but are when they come out and ruin the clothes I cannot get them off. Its got to be the machine
i thought my machine was doing that same thing once. then i found a tube of chapstick in my pants pocket that got washed. that looks just like an oil stain on clothes
OIl stains on clothes with front loading LG washer
ftr loader washers do not have any oil, my guess would be you are using fabric softner . that can stain clothes. dilute with water, they are very concentraded. or your dispenser may not be working properly and not releasing softner at the proper time.i would run a clean cycle through it. meaning set on a hot wash- regular cycle no clothes and run wirth bleach in bleach disenser. do this every other month to keep washer clean hope this helps. make sure its not happening in the dryer , the dryer has frt and rear seals that go bad and start leaving marks on clothes and catching them in beteween the tub.
Washing machine smell
You need to use a steel wool with alot of ajax/comet and start scrubbing the entire inside of the tub.Its not going to wash out any other way.
2answers
Leaves
with the exeption of something you mistakenly left in your clothing and wound up in the washer, not likely stains are from there , most of the time they do come from the dryer, try grabbin an old white rag nad runnig it around hte fron of hte dryer drum and then tyr the rear where the drum meets the back bulkhead. usually leavs brownish streks smome what curved 2-3 inches log. its from hte felt hte supposed to seal the drum. its either wearing thin, or a glide has worn away causing the issue
4helpful
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Top Washing Machines Experts
john h
