ASUS P5PE-VM Motherboard Logo
fahrudin halilovi Posted on Jan 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How update bios
Rufus usb
Fred Oppous
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jan 21, 2015
Fred Oppous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
Helped
4319
Points
23
I had a P5B and what you did was copy the firmware file to a usb thumb drive. Then boot computer and go into bios and there was an option to flash. Then choose the file on the thumb drive.
Lars Olsson
Level 3:
Brigadier General:
  • ASUS Master 3,400 Answers
Lars Olsson
ASUS Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1048797
Points
10330
TRY THE SITE WIM'S BIOS.
bzet1820
Level 3:
  • Master 700 Answers
  • Posted on Jan 20, 2015
bzet1820
Master
Level 3:
Answers
700
Questions
Helped
211599
Points
2147
It is rather ancient m/b, asus stop producing it i think in 2007 or 2008, i think last support for it was in about 2010, please follow this link and read manual as well as download your bios update as well as little program installing it, READ THE MANUAL!:
http://www.asus.com/Motherboards/P5PEVM/HelpDesk_Download/
hope this will help you, do not forget to vote...
Unable to upgrade it to Window-10 for Gateway DX4885. It throws an error while installing the update
Copy and paste the following link into your web browser:
https://www.alphr.com/upgrade-windows-8-1-to-windows-10/
Windows 8 is 'old hat' now and you may have difficulty in upgrading, if it is actually still possible.
Your computer is old? There's (old) 32 bit computers and more modern 64 bit computers. An operating system is designed for either 32 bit or 64 bit.
What you can try is another OS such as Linux. Run it as a 'live version' to see if you like it before you install/use it. All you need is a usb drive or dvd that can be written to.
1. Download rufus
https://rufus.en.lo4d.com/windows
2. Download a Linux iso image - such as Desktop Ubuntu (it will download into the downloads folder)
https://ubuntu.com/#download
3. Insert the USB drive into your computer
4.Open rufus - navigate to the download folder and install Ubuntu onto the USB drive. (simply copying and pasting the files will NOT work. You have to make a bootable USB. Rufus does this for you.
You now have a portable OS on a USB.
5. Restart your PC and open the bios settings. Navigate to the boot sequence and change the first boot device to USB. Press F10 and exit. Your PC will then restart and run Linux from the USB. No changes are made to your computer.
You can either run Linux 'live' from USB or click on the desktop icon which says install onto computer.
If you wish - instead of putting Linux Ubuntu onto USB you can burn the downloaded .iso file onto dvd and choose cd/dvd drive as first boot device.
Again, simply copying and pasting the Linux image onto dvd will not work. You must make it bootable. I you don't have the software try installing k3b:
https://sourceforge.net/projects/k3b/
It's all actually quite easy to do.
I Have a Dell Latitude d400 laptop, I'm using an external floppy disk drive to try to load ms-dos back on my laptop, so when I restart my laptop I get the Dell logo then starting then A:\.
wow the only post world wide wanting DOS, are you just kidding OP?
why not just USE FREEDOS.
get RUFUS free, click the freedos box in RUFUS
the burn it to USBs stick and boot the USB stick
and now you have FREEDOS.
C:/ then type VER, enter, see FREEDOS.
park the floppies, in the landfill where they belong long ago.
2answers
Will a Xeon e5450 work on a Acer EQ35M motherboard?
Hello Rufus, I try to help you, but I need more information too many details to give you one simple answer...like Chipset, LGA Support CPU and more; I sent to you a website, then you can have some idea,
http://www.cpu-upgrade.com/CPUs/Intel/Xeon/E5450_motherboards.html LGA 771 to 775 Adapter MOD Run faster Xeon CPUs in Core 2 Quad motherboard...
1helpful
Always I get a message that says password of this corrupt profile user in everything i have tried to fix the problem
Try to find somto use utility to remove password, or reset...you can use Hirens Boot v15.2.http://www.hirensbootcd.org/download/..download it here and make bootble USB with Rufus https://rufus.akeo.ie/...or just go to Hirens official web site and download some password tools http://www.hiren.info/downloads/freeware-tools/ list there to find some.
Think that will help you!
Regards, Jovan.
Acer aspire one D270 is not allowing me to logon.
With another computer create a bootable Flash drive using the following program.
http://rufus.akeo.ie/
Download Ophcrack
http://pcsupport.about.com/od/toolsofthetrade/gr/ophcrack.htm
Use Rufus to burn the ISO to your flash drive.
Roboot your computer, start tapping F12 just before the Leno Splash screen starts until the boot menu comes up.
Boot to USB and Ophcrack should start up on its own, allow the program to run and it will do the work for you.
I need the tool named "bootsect.exe"
Why use bootsect?
Easiest and working tool I found to create a bootable USB from an image is "Rufus", found here: Rufus Create bootable USB drives the easy way
I made a bootable USB for Windows 8.1 installation and confirm that it worked.
Hope this helps.
How to unlock nextbook
you will have to format the drive and install the windows back on it. Download a windows disk of pirateproxy.se and then use rufus to make a bootable image pop ur stik in a usb port restart the pc select first boot priority the stik not the hard drive you can do so by entering the bios ( pressing f2 or Del after pressing the power button ) and from there u go to boot and change the settings then save and exit and then ur good to go. hope this helped.
Want to remove U3 software and completely wipe SanDisk Cruzer Micro flash drive.
Try using a tool like Rufus http://rufus.akeo.ie/ to format the drive to its full capacity. There are links on the page to other usb utils.
Cant boot from usb. sandisk cruz 4gb
These answers are garbage. You should be using "Roofus," you won't have to do any of that fancy formatting stuff. You can just select the drive and ".iso" file in the program and begin burning. https://rufus.akeo.ie/
Usb 2
Hi truckereric, The short answer no.
USB 2.0 is acheaved by two things.
1. You need to enter your system boards Bios. Find the USB settings. If USB 2.0 is listed here than your board will support it.
2. USB 2.0 is installed through windows updates.
3. If your board can't handle USB 2.0 maybe there is a Bios update. No, I checked your bios & there is no bios update to bring you up to USB 2.0.
AOpen's driver / software & bios support found at the link posted here. http://download.aopen.com.tw/Default.aspx
You'll need to fill in the three dropdown menues.
Motherboard
MX4BS
& Order by: LastUpdated
There are five pages of updates. If you change the Category dropdown menue to Bios. AOpen will show you the bios updates.
At least you have AOpends update link.
You can always add a PCI card that supports USB 2.0
http://www.buyextras.com/synecchusb20.html?gclid=CP_cvvGF_pECFQuAHgod0mYK4w
Best regards.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
