I turned on the key recognition for those with bad eye site and I want to turn it off...When i go to settings now it wont scroll..not even during web browsin so i cant get it to scroll down to do a fa
Cant scroll down in settings so nothing has worked
Open chrome browser open settings should be upper rite corner three little does open site settings scroll down to cookies open cookies and turn them on.
in settings, try to put the "sleep" timer to 2 minutes, and see if it actually locks (or sleeps:turn off the screen)... also with mine sometimes the "capture screeen" feature works (more donts than do's!) perhaps very poor quality from the buttons.
clean all the apps running, and start with a full fresh boot (turn off by holding the power button 10 secs or more, then conecting to the charging usb, press again the power button), the volume also can be set via software, again in settings.
Check its charger. If the charger is faulty, it won't charge the battery. If it is found OK, replace the battery. It is bad.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Before we begin you will need to have the following ready. ? The Coby
Kyros with a battery level of 30% or more, the USB cable and an empty
micro SD card with a minimum of 4G. The Micro SD card should be inserted
into the Kyros. Start by going to our website www.cobyusa.com to
download the zip file to your computer. The file can be found on the
main page for the MID7015. It is titled "UPDATE.ZIP". It is important
that you do not UNZIP the file.
Once file has been downloaded to your computer, turn the Kyros on and
connect the unit to the computer via the included USB cable. At the top
of the main page Go to the navigation bar and scroll down. A menu will
open with several USB notifications.
Click on the External USB connection. This connection refers to the
inserted SD card. A new menu will appear Click on MOUNT. Once complete
your computer should recognize the Kyros device. A screen will open and
show the Removable Storage drive. If this window does not open, please
go to the start menu of your computer and select computer or my
computer. There may be several drives shown. Please choose the one that
corresponds to the SD card, it should show as empty. Open the drive. Now
you may drag and drop the ZIP file into the removable storage drive.
This process will take approximately 1 minute to complete.
When complete Go back to the Main Screen of the Coby Kyros Once again go
to the top navigation bar and Turn off the USB Storage. Another window
will appear with a turn off message. Make sure to click on this as well.
Disconnect the Coby Kyros from the USB cord attached to the computer.
Then Press the Power button, it will again prompt you to power off from
the main screen twice.
Wait 5 seconds. During this time locate the power button and the return
button. Press both buttons at the same time. Continue to hold the
buttons down until you see the warning triangle and android logo. Once
the symbols appear you may release.
Press the return button again. The reboot section will appear. You will
use the Home and Menu keys to scroll through this section. The Home key
scrolls up and the Menu key scrolls down.
Scroll down to Wipe data/factory reset. Press the return button to
select. Scroll down to Yes and hit return. The Kyros will notate the
Data wipe is complete.
Scroll down to Apply SDcard and press return The Kyros will notate
Install from SD card complete. This will take approximately 1 minute
.Select Reboot system now and hit return key
Congratulations you have just updated your Coby Kyros For more info visit www.cobyusa.com Hope this support has been helpful? Thank you for visiting FixYa.
to enable writing you need either Win XP Tablet edition, Vista Home premium and up or handwriting recognition software. Microsoft office 2003 has support for handwriting as well, but it needs to be installed as additional package. There are also many programs available from other developers.
