SOURCE: not ejecting
DRUM FG
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA
SOURCE: JVC GR-AXM17U
In the case the encoder position is not shifted
to the next point though the loading motor has
rotated in the unloading direction for 4 seconds
or more. This error is defined as [E02].
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shif
SOURCE: I want to get the video on my JVC GR-AXM17U VHS-C
Software, Cables. Thats about it. There are a couple of ways to do it. If your JVC has a USB port & cable then using the software that came with the camera, OR downloaded from the manufacturers web site, install that, THEN connect the camera up, most likely it will show up as a "Drive" then you should be able to simply Copy & Paste your files as normal. Then once on PC you can manipulate them however you want. IF you have Composite Video & Audio OUT on JVC, and you have some method of getting Video & Audio INTO your PC, then you can also use this, Plug it all in, start your "Recording" software, then Press Play on JVC, You can get USB Video input dongles, 7 or, some video cards allow Video IN too.
Testimonial: "Thanks! That will work"
