Any suggestions are helpful
SOURCE: Connecting Computer to HDTV
If you use a graphics card with an S-Video output that allows you to connect to an S-Video input you can use that. Most computer graphic cards now a days come with an attachment that makes the S-Video output into a Component type connection which allows a 1080i image to be displayed on TV's. This is how I connected mine and you will have to mess with the color a bit to get it looking the way it suppose to.
SOURCE: Blurry image
maybe a dvd setting
try an other device in the inputs to verify its not the dvd
if you get a good picture through cable input then
component inputs (should be good)?
SOURCE: Watch movies from computer to tv
look on the back or sides of the unit. it should have a hdmi cable hookup, it will look like a monitor input, then you have to make sure you set the tv input to that. then you have to set your laptop to add another monitor to be able to use it.
SOURCE: I need help finding the correct HD cable for my TV.
yOU WILL HAVE TO HOOK IT UP ON THE COMPONENT INPUT THE VIDEO PART IS GREEN RED AND BLUE WITH AUDIO RED AND WHITE. OR IF YOU HAVE AN HDMI INPUT ON YOUR SET YOU CAN HOOK IT UP THERE.
Testimonial: "helpful, i have found some component cables online."
SOURCE: connect hp laptop to tv to watch Netflix downloaded movies
how do i hook up my hitachi tv to my hp laptop to get netflix?
