Robert, I will post links below that may address your problem. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
www.shopyourway.com > Manage My Life > Questions How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
mcdevito75 here, The temperature riseing to max the cooling off fast, could be a stuck thermostat of the fan switch for the radiator could be faulty. The hard start after a few hours could be a dirty gas filter. Bset Bet, have your local auto repair shop have a llok.
Remove the cover after pulling the power plug. Check the transformer and large capacitor for signs of overheating. If they look ok, then remove the sheet metal wave-guide from the area where the energy enters the cooking cavity. Under the wave guide is a fan-like device called a stirrer that has a plastic bearing. This stirrer bearing is commonly arced over (when the oven is operated with nothing to heat in it). Usually the bearing looks good, but has arced internally. Replace the stirrer as a unit. The machine can be operated with the case off and a cup of water for a load, but keep you hands clear. Look for smoke.
Hey there...All you have to do is press the CD MODE button while you press the on/off button and it will fix it. This happened to me as well and I thought that I was going crazy...I changed the 9 volt battery but finally got it to work.
Do as follows: 1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions) 2) push the crown in half way back (not completely) 3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done 4) when big seconds hand is zeroed push the crown back in 5) pull the crown out again and set desired time 6) push the crown back in. If
all actions described do not work, you will have to visit your nearest
watch repair shop and ask to refit chronograph hand as in this case it
is out of balance (not pointed at exact mark).
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Unfortunately Bose will not release their schematics or parts lists,
effectively giving them a monopoly on repairs. Their web site,
www.bose.com, offers to repair most Wave radios for $100 or to give
owners of broken sets a $200 allowance towards the purchase of a new
Wave. Before spending the big bucks though, you might want to check
out the new HD radios. Better sound and a MUCH lower price.
