The Sd (5d) error code is displayed on this washer when the machine control board detects a suds-lock condition by analyzing the drag on the washer basket. It will be displayed while the control runs a mini-clean out cycle. If this clean out cycle is unable to remove the excessive suds and correct the condition, then the cycle will end and Sd will flash in the display.
Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity in your washer. If you detect excessive suds in the washer, this likely caused your problem.
Another cause could be a toy or other item under the washer that would cause friction on the drive mechanism. If you do not see excessive suds, check for this type of problem under the washer.
