Nothing.........Maybe it is sprung?
Check the screws on that side where it's ready you might have to loosen them up and drop the door so it will fit perfectly
Hello Jerry;
My name is Peter. I am a retired field service appliance technician.
It sounds like you have a interference problem on the bottom right of your unit. Either the kick plate is loose or other bottom components are loose or have lost a fastener. You may have a bad support plate, on the right where your spring action is located.
Go into the following link to obtain a manual for your unit, to locate the above mentioned components.
Home
