I think the USB cable is defect, or one of the connectors, on the tablet, computer or even on the cable. First try a new cable and check if nothing is in any of the connectors, like dust or other debris.
that happened when i first got my mp4. i just left it on charge for a few hours and eventually it turned on. it should tell you when its fully charged.
theres two ways mine can turn on; (its most likely very different to yours though) theres a little switch on the top of the player and you flick that to the left side. or if its been turned on recently, you can hold the play button. does the instructions say to press the ok button?
Sometimes with mp3 players the cable is the one that is mostly damaged. Try replacing this cable and try again. It actually has happened to me on two different mp3 players. Cables are always faulty.
You don't say how old the device/battery is. Does it fail right out of the box new? This behavior can be common with an older failing battery. If this occurs in a new device then it is faulty and needs be sent back on warranty.
Go to settings and look under system.Then look where it says usb peference then see if it says windows media device if not change it to this and if that doesnt work try the other settings.If that doesnt work go to Archos.com and contact them and see what they can do.
I have found a solution for this issue, if you hold down the volume button and the power button for several seconds the Archos goes into a restore type mode. You then plug it into your computer and download the latest firmware update and cut and paste it onto the archos removable hard drive icon that appears in my computer. It will take a few minutes to update but then it will work perfectly.
if you are having technical problem with your archos 605 just do this connect your USB with your computer and your archos device will pop up on the screen asking you if you want to charge your device or enaable usb that will automatically appear if your computer doesen't reconise the device then switch it off and on again if doesen't work then i suggest you look it up on the archos manual which is located on your device. if that doent work then i think you may need to update your computer it must have windows Core dual processor if that don't work and your archos device doesent appear then i think you may need to update your computer with a service pack 2 installation cd
