I suspected grease etc clogging it . Took it apart today and cleaned. Motor was not that dirty but am beginning to suspect the motor. Oven was already in the house when we bought it and have used for the past 8years. After putting it together ,the problem persist. Any suggestion will be appreciated. Also i notice when I took it apart today that,the cable run all the way from the lighting unit and was soldered onto the fan motor. Does it mean a new motor comes with all that cable already soldered.? Many thanks
SOURCE: Neff extractor fan not working
Hi rags116,
I'm Harvey the Master Plumber.
Your problem is: You have a neff extractor fan which hasstopped working. The light and fan have both stopped working. Do I know where you can find the fuse as you suspect that this may be the problem. If I don't think it is the fuse would I be able to suggest anything else.
The type is D-AY25-8 If there is another number that is more helpful please let you know. thanks Again your Neff Series 2 extractor has stopped working and you want to save yourself buying a new one!! Any suggestions greatly appreciated!
Since both light and fan require low voltage it sounds like a bad transformer. It will be mounted next to the motor. Make sure you turn off the power first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: Rangemaster 110 Fan runnig slowly
Needs new fam assembly.We can supply parts if [email protected]
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
SOURCE: attic roof vent fan- brand unknown. need motor and blade
Any Blade will be ok if it will fit shaft and they all should be cosistant and of course the higher the amp the better quality.I like the Pro 3 model at Home depot but I believe the Pro 1 gable is the 12 inch blade,pro 3 is 17 inch houseing and maybe 12 inch also.
Please rate jj505 Guru
SOURCE: Dacor RV46 Inoperative
Tom - Did you ever solve this? i have the same thing going on?
thanks
Bill
