It is not a make I have heard of before, which is odd, because I spent 50 years in catering and hospitality. Parts are available according to this. Getting to the snap ring would be the issue. You may be able to pull the old one out with a right angle pick and push the new one in.
The shaft of the paddle is bent. After frustrating discussions with Cuisinart customer service, I was able to free my paddle. First, you will notice that the paddle screws onto the shaft. Unscrew it. Then, take the nut off the shaft. Next, put a wrench on the shaft that is only slightly larger than the shaft, followed by a washer. Next, screw the nut back onto the shaft. Finally, holding the wrench at the end, hit the wrench close to the shaft with a hammer. If the shaft doesn't come out, hit harder. Since the shaft is bent, you'll need to purchase a new paddle.
type delonghi in the search bar. Pick a site and yell at them. Kidding, tell them your problem and they should work with you. Get a phone number and call them, get the salesmans name and a time frame you can expect repacements.
I had the same problem. Had to strip the machine down to get to the motor. On the top is a moving plate with various capacitors etc mounted. On the front side there was a Capacitor (At least I think it was) with the wire broken.
I resoldered it and the machine now works fine.
Check eBay. They frequently have them.
