Johnny,
If generators are not used regularly, they need the their magnetic field to be charged (or flashed). This can be done by plugging an electric motor into the socket while the generator is running and spin the motor by hand. The hand-spun motor will push some electric current back into the generator and magnetize it enough to start it.
Look in the manual. There is likely something about field flashing the
magnetic field. The easiest way to do this is to.
1) start the generator
2) plug an electric drill into the generator (without drill bit)
3) make sure drill is set to forward direction (if a reversable drill.
4) pull the trigger on the drill.
5) If the drill does not start, spin the drill's chuck clockwise (When looking down at the chuck from the drill bit end). Spin counter-clockwise if holding it like a pistol and pointing away from yourself.
6) Do this several times (hard) until the the generator will kick in and suddenly make the drill spin at full speed.
Be careful not to drop the drill or poke someone with it as you celebrate success.
