SOURCE: dell a940 printer
Had the same problem. You should just buy another printer... they are so cheap these days...
Best,
David I. Bleckner
SOURCE: My Dell A940 is not printing with black ink.
how long have the cartridges sat? I've noticed after about a week, that dell ink clogs up. Also, Lexmark makes most Dell printers. In my time as a cartridge refiller, we blow through dells and lexmarks and when they **** out, usually it acts like it prints, but nothing comes out printed, only blank pages
SOURCE: lost my installation cd for A940 all in one printer
Go toy www.dell.com, click on the support link. Lookup your specific pronter model #. A list of all available software/drivers will appear. Download and install the ones pertaining to the operating system you are running. You should be all set. Hope this helps.
SOURCE: dell a940 printer error 50 c tried without
I had this same problem. I solved it by cleaning the bay where the cartridges go with some 100% Isopropyl Alcohol. Then i just replaced the cartridges with new ones and it worked fine!
SOURCE: dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low
once it reaches a certain level. The sensor can not be reset. If you
refill an ink cartridge that previously reported low ink, it may print
fine, but the sensor will always report low ink. Buying or replacing
ink cartridges with new Dell cartridges will resolve the low ink
message.
Dell discourages ink refills. Refilling ink may lead to print
quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
