Started to remove old seal, not sure how it comes out
SOURCE: Ariston dishwasher LL64
usual place for a leak is thro the door main seal but it is possible to get a leak thro the dispensor. only way to check is split door, put it to work and see if it leaks in dispensor area
SOURCE: aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
SOURCE: ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
SOURCE: I have an ariston amd 129 washer dryer. F-10 keeps
F10 - Pressure switch not sensing correctly. blow in to switch gently it should click. blow into pipe should be clear.
SOURCE: Ariston "Margarita 2000" Model AL129X [front load washing machine] - Clean sludge from door seal.
Ariston "Margarita 2000 cpu map photo
