TCL E3010 Series LE40FHDE3010 40" LED TV 1920x1080, 60 Hz, HDTV Logo
Becky Sanchez Posted on Jan 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 40" TCL TV with one black vertical line on the screen.
It has no t-con board so what's next?
Practical Guide
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jan 03, 2020
Practical Guide
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
11
Questions
0
Helped
16406
Points
52
Its looks like your LCD TV screen going faulty but first clean your FPC cables{Flat Panel Cable} of LCD screen and check.
shadowchb
Level 2:
An expert that gotĀ 10 achievements.
Sergeant:
  • Expert 268 Answers
  • Posted on Jan 14, 2015
shadowchb
Expert
Level 2:
Sergeant:
Answers
268
Questions
0
Helped
73840
Points
865
Your set has some board that performs the function to connect the screen to the video-generation function of the TV. Either your LED/LCD screen is failing or the video function is failing. If the set is under warranty, contact the manufacturer using the information on the warranty statement. Try using a different video input (hdmi/composite/etc) for the TV and see if you get the same line on all inputs. If there is no separate board, the next step would be to try and replace the main video board. With the prices falling on lower resolution TV's, it would probably be cheaper to replace the TV than trying a repair, if it is out of warranty. 40" 1080p TV's can be had for less than $200 at some sales (e.g. Black Friday).
Tcl 55s425 I get the back light but no display and some vertical lines
Hi Bruce, what's going on with you TCL set is one of the COF IC's on the panel boards is shorted, that's why it blew the power fuse on the tcon, a new fuse will blow and not fix it, don't order a new board as that won't help either, the set unfortunately isn't going to be fixable as a new panel won't be available and when they were a few yrs ago they run as much as a new set.
I have a E60 Vizio TV that has vertical black and white lines on 1/2 the tv. I replaced the T-con board but that did not fix the problem.
The T-con board is for the led backlights!
Are the backlights working? Sounds like yes even before changing the T-con board!
Did you do the flashlight test into the screen to see if there is a faint picture? I guess if you did you didn't see a picture!
This would point to the main board or the cable from the main board to the screen!
1helpful
2answers
My LCD TV has a vertical line on the right side of the screen. What causes that?
I hate to give you bad news but I believe this will be a panel issue and it's not going to be fixable. You can try a different tcon board but I don't think it will help
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ā€Ž24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Thin black vertical line near the centre of the screen what is the cause?
ok go to menue if still you have this problem your panel is not good
but if this problem disappera then this the problem of your T-CON BOARD for falt cables that attached to T-CON board
LG LCD TV 42LK450 - Sound but screen is black..
Sorry but you have a bad panel. Repair cost is prohibitive. The T-con was a good choice, but is the last step to the panel.
My led tv has a vertical line black at upper area
The T'Con board fault can result this type of display error.
3helpful
2answers
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
2answers
1/4 of my sharp aqous tv has lines in it
This lines are in colors or black vertical lining in shaping?Yes?These lines are not causes by u or causes by an object by using forces hitting the LCD screen panel itself to causes these problems?Yes than the LCD screen panel are dying and leaking radiation can't be repair only by replacing new LCD screen panel not worth replacing and reparing if require a new LCD screen panel only.If these vertical lines are in colors or black are showing up and causes by the tv itself?Yes.Than the tv have a dying board that call the T-CON board and this board only job are docoding any pictures pixels before it showing up to the tv LCD screen panel.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjmmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
We have a KDL40V5100 which is about 18 months old, we are now seeing a vertical line in the center of the picture which appears to be worst when there is a lot of action going on. It is almost like the...
Yes,this causes are bring it on by a board that call the T-CON board.This T-CON board it is slowly shorting out and slowly dying to bring these vertical lines up and showing up onto the tv LCD screen panel.This T-CON board jobs are to control and filter all the tv pictures pixels before it show up on the tv LCD screen panel.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-CON board for the replacement.
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
john h
ADMIN Andrew
ADMIN Andrew
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
