Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
Find the pink Clear button on the Control Panel of the WorkCentre.
Find the button below the word Auto.
Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
Press the green [Start] button.
Press the pink [Clear] button two times.
The WorkCentre should now warm up and come to ready.
If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
H4 is probably a fuser temperature code. Sadly the 161 is obsolete and parts are no longer being made. You'd be wasting money getting a new fuser for it. Time to upgrade.
In Toshiba Printer the error codes generally occur due to instability of drivers in system and also due to system related issues either it is supporting or not .So for proper assistance on this issue just get connected at Toshiba Printer Support Number 1-800-243-0019 and get in touch with expert technicians and get your issues resolved. Visit: Toshiba Printer Support Phone Number 800 243 0019 for Help
h4 low heat from heater unit do the following [c key]-[auto/text/photo key]-[c key]-[auto/text/photo key] machine will go dead key in 14 press print machine will cycle if the error code returns you will have to replace thermistors and thermofuse
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
If the machine dies enter 14 then press start. the machine will reboot normally.
