I have a Sylvania sylwh930 Wireless Headphone..I have DirecTv, my main TVand a second TV in my bedroom. I am able to use the Wireless headphones on the main TV, but when I hook another set of the same Headphone system, I cannot get any sound for the TV..I get the FM radio stations, but no TV sound. The TV in the bedroom only has a audio hookup in the back for the red and white connectors..Is there something I need to do to solve this problem?
SOURCE: innovage wireless headphones/how to connect to TV?
I have a plasma, and found when I plugged my HDR65 to back of the plasma audio out, it worked fine. does this help?
SOURCE: fm wireless headphone batteries not charging
you need to replcae the charging pin of your head phone, it is having loose connection............
SOURCE: wireless headphone hook up
Hello depends on how you hook it up as thee are several ways.
many receivers will output sound through the headphone jacks even when the speakers are left on.(my receivers require that you manually turn speaker A off when using headphones)
it may be possible for you to connect the headphones to a tape output but this will require headphones that have a volume control on them or an external.volume control knob.. You may encounter a problem as I am not sure if a tape output will provide enough signal to drive a pair of headphones. this would not be a problem if you use a pair of WIRELESS headphones as they have their own power source onboard..
A set of wireless headphones could also easily be connected to the output on the back of the TV but assuming you have your receiver plugged in to the TV audio out you may need a couple of Y adapter cables.
Also if your receiver has a pair of PRE OUT jacks those would work to power a set of wireless headphones may also power a wired set but once again not sure on power as I have never needed to try it.
Hope that helps a bit
Testimonial: "thanks for the input. This is the best solution I have received to date. I can not wait to try them Arthur"
