I have tried almost everything short of taking the phone apart. also tried Odin mode but it was on that for about 48 hours.
Quel est votre t?l?phone avec lequel je peux vous aider,
Have you tried re-flashing it?
Was you trying to put a custom rom on it?
Have you tried to return it to stock?
Try these sites. Stuck in green android logo
This site helped me a lot. You may have to dig a bit for what you want but i am sure its there.
Android Area51
Rember to use key words like galaxy xx, green android logo, stuck on xx screen
SOURCE: Nokia N73 ME phone memory shows full but not full
change the optional memory to memory card as the phone memory is filled completely.generally messaging uses the phone memory to operate.Messaging->options->settings->other and change the memory is use to memory card.that should solve the problem. This problem is certainly not with the memory card.hope this helps you out.
SOURCE: blackberry curve won't turn on...
Wipe it to start over. Sometimes when you change or add something like a THEME or a download it HOSES the BB completely. So delete what was on there and don't download a theme or any other wacky add-on.
To Sanitize or Clear out all the information in a Blackberry Device
Scroll to select the OPTIONS icon and press [Trackwheel] to select.
Scroll to select SECURITY and press [Trackwheel] to select.
On some units you may have to select GENERAL SETTINGS before getting the next menu.
Press [Trackwheel] again to access the Menu screen for the security.
Scroll to select the WIPE HANDHELD and press [Trackwheel] to select.
Scroll UP to select CONTINUE and press [Trackwheel] to select.
Type blackberry on keyboard to confirm the action press <-| key.
System responds with ERASING INFORMATION.
SOURCE: Shows fully charged (plug icon), but isn't taking a charge. A;ready tried reboot/restore.
Get a can of air and blow it into the 30-pin connector and headphone jack to clear the phone of dust and build-up. This should clear up the problem. I learned this from an Apple Store Genius Bar associate.
SOURCE: I have a LG GT540
hey man ok so go ahead and pull out the battery ok re install batter and before you turn on again hold the volume down key and then turn on the phone while holding down the vol down button when you get to the system recovery screen it will say 2e recovery just reboot systom from there and you should be all set
SOURCE: LG Optimus blank screen
This sounds to me like the LCD Backlight has gone bad. You will need to get in contact with your carrier to inquire about warranty service or replacement.
