I-INC UniK Trio AXS 3G with Wifi 7.85" Touchscreen Quad Core Tablet Mach Speed 1.2 GHZ 16GB 2014 Release T-Mobile 3G Slim Folio Case [Bonus Stylus] - Hot Pink Logo
Luis Posted on Jan 14, 2015
For some reason I can't hide my icons on trio Axs 3G can anyone tell me where can go on my settings
My tablet wifi will not turn on i already try to hard reset it
has it got an aeroplane mode in the settings that might be on ?
or a manual switch that might put it in aeroplane mode.
My tablet won't save to its SD card
Try another sd card to see if the problem lies with your original card or the tablet itself.
2answers
My tablet was stolen and I am trying to figure out how to locate it if it is used.
did you install any app that has an anti-theft service,,it is very possible if such kind of application is there..
Good luck
1helpful
2answers
How do i get my axs trio tablet out of demo mode and user terminated?
This is how to remove the demo mode from the Trio AXS tablets:
1. Start tablet. When demo mode starts, click the menu icon and find the CALCULATOR app.
2. In CALCULATOR, type the following "!(364)!" (no quotes). This will put you in admin mode immediately. Click CONTINUE.
3. Enter the password: "Adm!nTr10!" (no quotes, mind the case). Now you have a list of options.
4. Un-check all the BLOCKED APPS.
5. Un-check all the items under DEVICE MANAGEMENT.
6. Exit and reboot.
you're done.
2answers
My WiFi is up and running and my other devices can connect but my trio tablet says authentication problem, why can't I connect?
I'd make sure that you have configured the correct wireless security type. If your tablet allows both WPA and WPA2, make sure whatever you selected matches the configuration on your WiFi router. Also, the encryption algorithm has to match - AES is the most common but some older routers only support TKIP.
Why I have to double click on the screen every time, and it's hard to scroll on the screen of My Trio Tablet?
This is an indication of limited RAM left, usually below 200MB. There are too many apps running in the background or an application consumes too much of the RAM. Use a Cleaner application to clear unnecessary cache which is normally the main culprit. ES Task Manager can do a pretty good job for this.
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
Ho do i take music and pictures off my trio axs 3G tablet because my screen is broke in the top half
connect it to your computer with usb cable and copy files to your computer it should ask you when connect it what you wanna do or you can use my computer or start menu to browse the tablet and select files to copy to the harddrive
My Trio tablet I lock it and don't know how to unlock it
YOU PUT YOUR PASSWORD IN OR YOU FORGOT IT ?OU MAY HAVE TO TOTALLY RESET ..USAUALLY PUSH VOLUME CONTROL AND ON BUTTON AT SAME TIME TO GET TO RESET MENU
Top I-INC Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an I-INC Tablet and eReader Expert? Answer questions, earn points and help others
