My 4gig SD seems to be defected, causes menu crashes, yellow logos with questionmarkes before it crashes, i've tried reinstalling it manually, but it still crashes... can't work with the SD chip because the phone somehow detects the chip, but can't hang on to it...
LEO Privacy is probably one of the best privacy apps ever. Also there's this thing were it boosts your storage, which it does, but I still have to go in the settings to clear somethings. But an app can only do so much so I don't worry. You should get LEO Privacy.?? LEO Privacy Applock Boost Hide Android Apps on Google Play
My phone isn't very well, so I want to find an app to clear junk and cache, now I found it! That's LEO Privacy, it uses a little storage, and with it, I also make my phone light. This is a wonderful app! This is also the best app that I used on my phone. LEO Privacy Applock Boost Hide Android Apps on Google Play
That means the driver is not working and or there is a problem with the firmware. You can go to Gateway, updates and downloads. Find the drivers for your model computer and download the drivers you need, which should fix the problem. If you have upgraded to a different OS, windows XP to windows Vista or 7 ... You can check for system drivers for these systems, or operate in the mode of you old OS but it sounds like a driver problem.
I guess you put the SD adapter into the card reader right out of the box? You first may have to partition/format it after unpacking it. Under WinXP I can recommend an utility "DiskPart" which you can start from the command prompt (Run... -> cmd). For further instructions (if it sounds to you to be the problem ) contact me again.
Check in the computer management / device manager window and see if there are proper drivers installed for the network / wireless card. If you are running windows XP take note if there is a red x or a yelloe questionmark. If there is a red x then the hardware is disabled. Right Click on it and left click on enable. If there id a yellow questionmark then Right Click and then left click on update driver. If you are running windows Vista then you will see a black linr under the device. You can try the same steps. I hope this helps.
