Question about Bosch Dishwashers
Bosch sms 5072 heater won't turn off. Goes through cycle normally, but heater stays on.
    Genius:
  • 1,075 Answers
Sounds like a small capacator in the main circuit has blown its better to buy the circuit board I bought one last week and it cost 37gbp ie stirling,go to bosch dishwasher circuit boards.com.adrian....
Posted on Jan 28, 2015
6ya staff
SOURCE:
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
Machine won't start the wash cycle
All bosch appliances are sold with a two year manufacturers guarantee. Call 0844 872 8999 to arrange an engineer. Sounds like it could be any of the following Heater, PCB, Pressure switch or Motor fault
Mar 24, 2013 | Bosch Washing Machines
My Bosch SHU5316UC won't finish cycle. When I turn it on it resets to 13 minutes and goes down to 1 but stays at one and never finishes. Except on rinse and hold where it goes to 1 and stays there. It...
Hello, welcome to FixYa.
Based on your description
I'd say the issue actually with the control...unfortunately. The "1" being displayed is actually an error code associated with a heating fault.
**B/S/H/ issued a recall on certain models between 1999 - 2006 depending on the model & serial number, you can check with yours but...you'll need the serial number too. Here`s the link if you want to see for yourself **
https://microsites.boschappliances.com/safetyrecall/dishwasher/
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...or takes a long time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness. Good luck.
Regards,
Macmarkus :)
May 23, 2011 | Bosch SHU5316UC Dishwasher
Bosch AquaStar 125b ng suddenly goes cold during shower
Does it happen to any other fixture? If not, it's most likely your shower valve and not heater.
Sep 01, 2009 | Bosch AquaStar 2400ES-NG
No manual for my dishwasher
This is not the kind of thing you want to tinker with without a manual. You'll need the model# and serial # to contact Bosch and get a manual.
Aug 19, 2017 | Bosch Dishwashers
Dishwashers Logo
100 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
