HP OfficeJet 7410 All-In-One InkJet Printer Logo
Posted on Apr 20, 2017
A HP Officejet 7410 all-in-one-print queue problem
Even if I only want to print one page in the HP box which shows the jobs waiting to be done the pages column will say 3/1 or 4/1 pages to print, (which doesn't make sense). It may have said 1/1 at first but then changes to 3/1 etc., even while i watch. I can't print anything else then, I can't delete the job that says that, and can't print anything after it says that. I have to not only close down my computer but also the printer as well for a minute. It does this on every 3rd or 4th job to print and is highly annoying to have to continually shut down the computer and printer. Any ideas?
5 Related Answers
A
Anonymous
  • Posted on May 25, 2007
SOURCE: Deleting - Printed
GregoryW's solution worked on a Dell AIO A940, except when I deleted the existing print spool files, the printers disappeared from the Printers and Faxes folder. I had to undelete one of them then the rest of the solution seems to have worked.
Anonymous
  • 21 Answers
  • Posted on Sep 19, 2007
SOURCE: job in queue
Let me exaplin the cause why the jobs get stuck in queue: When ever we try to print there is a windows service called print spooler that manages the print jobs in queue. We can clear the jobs in queue by just disconnecting the usb cable and restarting the print spooler service. Here are the steps to restart the print spooler : 1.Click on start 2.Then click on Run 3.In the Run box type " net stop spooler " Then press enter Note: Type the text with out inverted cotes in the run box this will stop the print spooler service Next we have to restart the print spooler 1.Click on start 2.Then click on Run 3In the Run box type " net start spooler " and press enter Once done reconnect the usb cable and check for the jobs in queue. If there are no jobs in queue you can set the print directly settings to avoid this issue in future. Just open the printer and faxes folder and right click on the printer icon and select properties and then click on the advance tab and under it select the option print directly to printer and click on apply and Ok to save the settings. Once done try to print this should resolve the issue.. Wish u success..
Anonymous
  • Posted on Sep 25, 2007
SOURCE: The printer keeps printing pages of single line code even offline
hi i am having roughly the same problems i use cad and have not even managed to print that far yet what windows are using?
websnail
Martin Smallridge
  • 419 Answers
  • Posted on Jan 25, 2009
SOURCE: printer will not cancel print job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Anonymous
  • Posted on Feb 13, 2009
SOURCE: HP LaserJet 1022 Printing Blank Pages
I had this same issue, are you able to print from the printer's internal test feature?  If so try turning the power off for at least 10 seconds.  This is just at temporary fix I am still looking for a permanent fix that does not involve replacing the printer.
1helpful
How to i clear the queue with jobs waiting to print when the printer says printing but is not printing
Try pressing cancel on the printer first. Then, open the print queue by opening the printers folder, and double-clicking the printer icon for your printer. Try to select the jobs there and cancel them. If that doesn't work, turn off the printer, and wait for the title bar of the print queue to say "use printer offline". If it doesn't change on the title bar of the queue, then select "use printer offline" from the file menu of the print queue. Then try to delete the print job. If this still doesn't work, leave the printer off and reboot the computer, then try to delete the print job again if it is still in the queue. If none of these work, remove and then reinstall the printer as a last resort.
My printer won't print. it sends the jobs to the "queue" but doesn't do anything. what do i do?
First of all whatever jobs u have sent to the queue ... pause it and go to services.msc and stop the print spooler services ... minimize the page and delete the print jobs from the queue.... go back to services.msc.... restart the print spooler services..... if that does not work .... follow the detail link : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00843712&cc=us&lc=en&dlc=en&product=1138342
2helpful
2answers
7310 wont print
u have to clear the sent job, go to printers and faxes through your start menu, if u cant find it there, go to control panel, double click on the printer and faxes icon, on the pop up window, double click to open the printer then select all the jobs and empty the box, then you can start using again, make sure the printer is off while doing that.
1helpful
2answers
HP OfficeJet Pro l7500 won't print. Printer queue shows 5 jobs with error on first 2. I tried twice after rebooting the computer.How to print , or how to download proper driver? SB
Officejet Pro L7500 is giving me error message that it can see the black and yellow print head I have replaced it and it is still giving me the same error.
Is there a way to clean it with out having to have it taken in to be repaired?
Not printing hp officejet 5510
plz delete all the printing job from the printer and reinstall the printer. plz post your findings
HP 7410 off line with Vista & HPM8000 computer
Once right click on the printer icon and make it online and then clear the print que and then download and install the patch from the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-54112-1&lc=en&cc=us&dlc=en&product=391194&os=2093&lang=en
After installing the patch restart the computer and check for the result.
HP7410 Print Problem
http://h10061.www1.hp.com/ccsearch/search?cc=us&lc=en&dlc=en&sni=391194&opname=HP+Officejet+7410+All-in-One&pname=HP+Officejet+7410+All-in-One
copy and paste the above link into your address bar and search for the answers.
11helpful
2answers
Job in queue
k24674
Grand Canyon Tech
Grand Canyon Tech
