Unplug everything,disconnected power and tried to put the power back on,it says hello ,please wait and directly shuts down with blinking red standby light
SOURCE: No TV audio coming from Sony DAV-HDX500.
If you are trying to make your TV audio come out your Sony system, you didn't say what the input to your TV was from (ex;Cable TV,Sat TV).
Sometimes it is easier to take the external (cable or Sat) out puts and feed the video into the TV but the red white into the AMP (TV input)then select TV on your AMP to hear TV.
Also some tv's need to make a speaker choice! go to Set up and change the speaker set up for the TV, you may have to tell the TV no speakers to create out put to Amp from the REd White TV out put.
SOURCE: Blinking standby light system will not turn on
I was having a similar problem and determined that there was a short in the speaker leads for the center channel speaker. The leads to the speaker were touching, after being moved, slightly while housecleaning. Once short was eliminated, unit powered on and worked with no problem.
SOURCE: DVD does not work...no lights are on
its better to buy a brand new than to diagnose cause it will be damage again soon.. your money will be useless.
SOURCE: Sony DAV-C770 Red Light Flashing but nothing is on!
power supply or power amplifire unit problem.give it to repair proffesional.
nuwan.
SOURCE: Sony Dav-C770 blinking standby light product will not function
I had the same problem, red blinking light after owning for several years. I decided to replace the capacitor at C914 to see if it would work, and it did. Apparently that capacitor is prone to failure. Since this seems to be a common problem, I created a web page detailing the repair. Hope it is helpful. Repair cost $1.39 + tax.
http://hancockfamily1.googlepages.com/dav-c770repair
