Hello Scott, to be able to guide you, in wiring so that you can have everything in your home theater system, you should comment that equpos you have
I can suggest a generic connection to have the sound of each source in Tu Onkyo
You have to connect the equipment that has HDMI output, in the corresponding entries in your Onkyo, accounts with only three inputs, if you have more than three equipment with HDMI, you can connect it to an HDMI input on the TV
If you have other equipment that does not have an HDMI output, you should connect it to the remaining inputs of the Onkyo, according to its type
Then, you connect an HDMI-HDMI cable from the HDMI output of the Onkyo, to the HDMI 1 input, of the TuTV Insignia
And you also have to have a Fiber Optic cable, connected from the digital audio output of the TV (it is located on the side panel of connections) to the Fiber Optic input (Digital In) n ° 1 of the Onkyo, this connection allows you to listen to the sound on the Onkyo of everything you are looking for on the Internet, eg Netflix, YouTube, etc.
In this way you would already have everything connected in the Onkio and you could enjoy the sound of the Home Cinema System
I hope you manage to interconnect everything and you can enjoy a good sound and an excellent image
I send you the links of the user manuals of TV Insignia and Onkyo, in case you need more information
Greetings Franco Dosil
Hola Scott, para poder guiarte, en cableado para que puedas tener todo en tu sistema de cine en casa, deberias comentar que equipos tienes
te puedo sugerir una conexi?n gen?rica para tener el sonido de cada fuente en Tu Onkyo
Tienes que conectar los equipos que tengan salida HDMI, en las entradas correspondientes en tu Onkyo, cuentas solamente con tres entradas, si tienes mas de tres equipos con HDMI, puedes conectarlo a una entrada de HDMI en el televisor
Si tienes otros equipos que no tengan salida HDMI, los deber?s conectar en las entradas restantes del Onkyo, de a cuerdo a su tipo
Luego, conectas un cable HDMI-HDMI desde la salida HDMI del Onkyo, hasta la entrada HDMI 1, del tu TV Insignia
Y tambi?n tienes que tener un cable de Fibra ?ptica, conectado desde la salida de audio digital del televisor (se encuentra en el panel lateral de conexiones) hasta la entrada de Fibra ?ptica (Digital In) n°1 del Onkyo, esta conexi?n te permite escuchar el sonido en el Onkyo de todo lo que buscas en Internet, ejemplo Netflix, YouTube, etc
De esta manera ya tendr?as conectado todo en el Onkyo y podr?s disfrutar del sonido del Sistema de Cine en Casa
espero que logres interconectar todo y puedas disfrutar de un buen sonido y una excelente imagen
Te env?o los link de los manuales de usuario del TV Insignia y del Onkyo, por si necesitas mas informacion
Saludos Franco Dosil
https://www.eu.onkyo.com/downloads/1/1/9/7/8/21637364_3342ba722d.pdf
https://data2.manualslib.com/pdf4/98/9771/977072-insignia/ns40e560a11.pdf?5272bbc74f2dc78e6eb01f3f6deb2aec&take=binary
