I tried gasline antifreeze but she still wont start
Fuel, spark, air is the fire triangle... You're unfortunately missing one of those... Try simply waiting for a long time an hour or so and jump starting the car if necessary.... my guess is that you may have flooded the engine with repeated failed attempts to start the engine. That means there is too much gas and the plugs can't spark because they're too wet with fuel...
SOURCE: 1999 plymouth breeze rom's running high
does it idle high also? i've had that problem, when i start the car (same as yours) it idles at 4.5rpms and after twenty minutes of driving for some reason goes to normal, i was told its a rpm sensor problem. good luck.
SOURCE: my car jump time
#1 are you sure it jumped time?#2 how do you know this? if in fact it has jumped time you will need to have the timing belt replaced.the average interval for replacement is 60,000-80,000.it is also a good idea to replace the water pump at the same time as it is driven by the timing belt.
SOURCE: How do you remove the starter from a 1999 Plymouth
On a 2.0 unhook the wires from the back of the starter then there are 2 bolts that go through the nose cone of the starter into the block, you remove those 2 bolts and the starter will fall out.
SOURCE: My 1999 Plymouth Breeze has the horn on all the
it is in the clock spring behind steering wheel contacts are broke completing circuit and making horn work
SOURCE: where is the crank sensor located on 1999 plymouth
The crankshaft sensor is behind the crankshaft pulley or harmonic balancer. You can access this by pulling off your tire and the inner wheel well. Then use an air impact preferably a 1/2 inch or 3/4 inch impact to loosen the bolt. Next you will need a pulley puller to got it off the sensor is directly behind the pulley make sure you set the sensor to where the old one was set at.
Please see my tip at http://www.fixya.com/cars/r5821173-doesnt_car_start_gasoline_engines . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
