Samsung LN40A530 40 in. LCD TV Logo
J
Jose Ramos Posted on Jan 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv ln40a530p1fxza colors are distortion
Colors are faded turn it on off
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Jan 11, 2015
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994876
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Lcd tv picture
Replace backlight lamps
Philips tv/dvd combo picture problems
if stretching is vertical! you have defective parts, like open resistor or change value resistor.
Color fading
make sure there are no external speakers near screen. the magnet in speakers can distort colors.
Picture is not very clear and the color is faded and can not adjust it
This mite sound crazy but it is time to change the oil in your TV. Yes your TV has three seperate picture tubes on the inside of it. A red tube, blue tube, and green tube. Each one of thses tubes has a clear oil that the light shines through. Over time this oil gets cloudy and distorts the light thus dimming and fadeing your picture please have a tech change the oil in your tubes.
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Phillips 43" T.V sound is fine Picture is Faded? Still visible but very light and faded..How do I fix
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Arc or hump on bottom left of tv and color is faded bad.
Your convergence Ic's have gone bad. Most likely a few small resistors with them. It's really not a job you should try and takle if you haven't done it before. Not a major deal for a svc co.
Green picture and distorted
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
