My 32" RCA gets stuck on one channel periodically. When trying the remote the green light on front changes to red, nothing happens. It wont change channels, volume or even shut down. I try the manual buttons, same thing. I have to unplug the power, wait about a minute, then it will only turn on by remote, the you have to use manual buttons immediately to get to another channel. After this everything works as it should, until you go back to the certain channel (6.1, digital attenna) and sometimes it gets stuck gain, sometimes it's OK. Also, if the TV is shut off on channel 6.1 you will be stuck when you turn it back on. If you shut down on any other channel it will start up an operate normally. I could delete channel 6.1, but we enjoy this channel and only have 4 others
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
I had the same problem and eventually found the solution. the tact switches behind the front panel buttons will leak when they get old causing them to activate on their own. your channel up or down button is stuck on. take off the back cover and you will see a small clip in circuit board behind the front panel. take out the board and remove the channel up or down switch and your set should work fine again. the remote will still work fine for changing the channels.
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions. Mac =)
If you are using the remote to change channels it sounds like either the front of the remote and/or the receiving “eye” on the TV need to be cleaned, OR (more likely) the button on the remote is sticking. It is actually a button that pushes on a membrane under the entire remote panel. This is generally caused by some sticky liquid (like Coke) getting spilled on it. If you are brave enough, you can take the remote apart and clean it with denatured alcohol.Otherwise you need to replace your remote.If possible borrow a universal remote and see if it still happens.If that doesn’t fix it you have a bad IR receiver and/or a serious internal problem.
Set-up in menu = step thru each page = skip what does not
apply to you = get to auto-program....be sure signal is attached
to set first.........................T.
The most likely problem is a stuck tact switch, if it goes up in channel number, 5, 6, 7, etc. then the channel up button is stuck, if it counts down it`s obviously the ch. down button. Problem is you have to remove the guts of the set to get at the control boards screws, you can try turning on the set and poke around the offending push button with a tooth-pick, if it stops changing channels leave it alone and use your remote from now on to change channels, if you can`t get it to stop the tact switches or the control board module will have to be swapped out, hope this helps
Usually the fix for that on a RCA or GE TV is to go into the menu (the button in on the front of the TV) and find channel settings and let the TV autoprogram itself. This should fix the issue.
