Are you showing the Dock on the side or the bottom, hidden or unhidden? System Preferences:Dock sets this.Are you showing the Dock on the side or the bottom, hidden or unhidden? System Preferences:Dock sets this.
You can't post conmments that contain an email address.
Depending on which email service you are using, I.E. Hotmail, you may only be getting a screen shot of the email. In other words it will only show exactly what your seeing on your screen if you simply right click and print. Hotmail has a little ACTIONS with a downward pointing arrow on the right side of your screen. Click that and select print and it will print the actual message instead of a screen shot of the message. I have to assume other email servers use similar techniques to print the actual emails instead of just screen shots. Hope this helps.
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
If you wish to get some details; visit the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
I had this same problem, there is a thin line of wires connecting the bottom half and top half of the sliders, after awhile it just plain wears out and will generally crack, without these wire anything on the front of your phone will no longer work. The screen is black but stil lights up a little bit and occasionally the buttons light up but its pretty much toast I'm sorry to say. I upgraded to a HTC Touch Pro 2 and am happier than ever!
Well try to boot into the safe mode.hit F8 on the startup and see if you get the same acreen.If its working fine in safe mode than you need to reinstall the video driver and that should resolve the issue.If it is still not working try connecting a external moniter.If you get the same display on the external moniter than its an issue with the video card and if you get a normal display on that than its an issue with the Laptop screen and you would ahve to get either of thses replaced by contacting the manufacturer.
Hope this helps!
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
