The error message "5h:0" on a Teka HL890 oven indicates that the oven is in demo mode. Demo mode is a setting that is used by retailers to show off the oven's features without actually cooking anything. To turn off demo mode, follow these steps:
Press and hold the "+" and "-" buttons on the oven's control panel for 10 seconds.
The error message will disappear and the oven will be in normal mode.
If the oven still does not heat up after turning off demo mode, there may be a problem with the heating element or the temperature sensor. In this case, it is best to contact a qualified technician for assistance.
Here are some other possible reasons why your Teka HL890 oven might not be heating up:
The oven is not plugged in. Make sure that the oven is plugged into an outlet that is working properly.
The oven door is not closed properly. Make sure that the oven door is closed all the way.
The oven thermostat is set too low. Make sure that the oven thermostat is set to a high enough temperature.
There is a problem with the heating element. The heating element may be broken or it may not be getting enough power.
There is a problem with the temperature sensor. The temperature sensor may be broken or it may not be reading the temperature correctly.
Two possible problems. If the oven has two or more elements for normal operation then one of these elements may be faulty. The thermostat may also be faulty and only heating to a far lesser temperature than required. The way to tell is turn the oven to a normal cooking temperature. If the oven indicator light stays on all the time and doesn't cycle off then it may be an element problem, meaning that the oven can't reach the temperature setting desired. If the oven indicator light goes off after a while and then cycles on and off then the thermostat is working correctly but the temperature may not be hot enough. You may have to purchase a small oven thermometer and check the oven temperature against the thermometer to get a better idea of what the problem is.
Hello, Please find here our reply from the customer service of Fagor America: This problem could be confusion over how to properly program an automatic cooking function. First, you must program the cooking duration, then you must program the time of day you want the food to be ready. Sometimes customers think they need to program a “start time” and an “end time” versus a “duration” and an “end time”. Please, make sure you are doing both steps correctly. Also, you should be aware that this clock works on the 24-hour principle (military time). I know that sometimes this confuses people as well. If both of those are okay, then it probably has a defective clock. If that is the case, please feel free to call our customer service: UNITED STATES OF AMERICA and WESTERN CANADA: Please contact ADCO Customer Care at 1.877.743.2467, or by email at: [email protected] EASTERN CANADA: Ontario, Quebec. Please contact A.G.I Service Inc: Telephone: 450-963-1303 or by email at: [email protected]. If you have any other questions do not hesitate to contact us at: [email protected] Best Regards,
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
