Question about Measuring Tools & Sensors
How do I change from Fahrenheit to celcius? Model # 00621cadia2
PRESSING THE SET AND ARROW BUTTONS.
    New Friend:
  • 8 Answers
You can download the manual here http://www.acurite.com/kbase/00621_Weather_Station.html
Set the Time, Date & Units Press the "SET" button, located on the back of the display unit, to enter SET MODE. Once in set mode, the preference you are currently setting will blink on the display.
To adjust the currently selected (flashing) item, press and release the "up" or "down" buttons (press and HOLD to fast adjust).
To save your adjustments, press and release the "SET" button again to adjust the next preference. The preference set order is as follows:
TIME ZONE ( PST MST CST EST AST HAST AKST) DST (Daylight Saving Time ON or OFF)*
CLOCK HOUR
CLOCK MINUTE
CALENDAR MONTH
CALENDAR DATE
CALENDAR YEAR
TEMPERATURE SCALE ( ?F or ?C) BAROMETRIC PRESSURE SCALE (inHg or hPa)
*If you live in an area that observes DST, DST should be set to ON, even if it is not currently Daylight Saving Time.
You will automatically exit SET MODE if no buttons are pressed for 30 seconds. Enter setup mode at any time by pressing the "SET" button.
Posted on Jan 10, 2015
    New Friend:
  • 20 Answers
To change the display units for the temperature, you will need to go through the set functions. Instructions to do this can be found in the user manual at http://www.acurite.com/kbase/00621_Weather_Station.html.
Posted on Mar 17, 2015
6ya staff
SOURCE:
How to change the temperature display from Celcius to Farenheit
Hello Friend, that's a great question!
Please follow the steps below to change the temperature to Celsius to Fahrenheit on your Frigidaire range, FEF366CCA.
    ·Press BROIL. "-" appears in the display.
    ·Press and hold the UP arrow until "HI" appears in the display
    ·Press and hold BROIL until F or C appears in the display.
    ·Press the UP arrow or DOWN arrow to change F to C or C to F.
    ·Press any control pad to return to normal operating mode.
    Hope this helps! - Z
Sep 03, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
How do I change the oven temp from celcius to farenheiton my Maytag Advanced System Model #MGR5710ADW
try unplugging range. If it does not return to F display
You can try this: Hold either timer keys down on power up. The right digit will display "F" or "C". The temperature display can be toggled from C to F by pushing the Broil key.
or
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit.
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/66531-switch-celsius-fahrenheit.html#ixzz37a4SP964
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/66531-switch-celsius-fahrenheit.html#ixzz37a4C5UH2
Jul 15, 2014 | Whirlpool Gold GW399LXU Gas Range
How do you Change Fahrenheit to celcius on electrolux fridge?
Good Morning Lize, thank you for allowing me to assist you!
Generally speaking, Fahrenheit to Celsius temperature can be change by pressing and holding the Fresh Food up arrow while at the same time pressing the Freezer up arrow three times in five seconds. I ask that you please follow up with a response on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully
Thank you and best of luck!
Oct 15, 2013 | Electrolux Refrigerators
Change celsius to fahrenheit
Hello deskds - To change Celsius to Fahrenheit for the model number posted above, press and hold the Fresh Food up arrow while at the same time pressing the Freezer up arrow three times in five seconds.
Mar 16, 2013 | Frigidaire Professional Series PHS68EJSB...
Honeywell rth 2300 celsius reading
Press both up and down buttons for 5 seconds
Release
press both up ans down buttons for 5 seconds again
Release
14 and ? small 0 will appear. Z?ro is for farenheit.
Use th? up arrow to change the 0 to 1 for celcius
Sep 24, 2012 | Heating & Cooling
To switch a Robert Shaw RS 3110 from farenheit to celcius?
First open the unit, as if to remove it from the wall by pressing the release button at the bottom of the unit and tilting it upwards. You should see a bank of 4 dip switches. On my unit these were red. Switch 4 selects temperature units. The circuit board is labelled Fahrenheit. Change this then close your unit and press the reset button.
Jun 22, 2012 | Shaw Electrical Supplies
My control somehow got turned to celsius or at least thats what it seems to be it will on set from 19 to 31 I see no way to change it back to farenheight. Help I can't be running up the electric bill...
Most of the time pressing the up and down temperature buttons at the same time and holding them for 3 seconds, will change it back to Fahrenheit
Thanks for choosing FixYa.
Aug 02, 2011 | Comfort-Aire RAD-101 Air Conditioner
MY OVEN IS VIKING OVEN CAN YOU PLEASE TELL ME HOW TO CHANGE FARENHEIT FROM CELCIUS
Hi and welcome to FixYa, I am Kelly.
Here is how you change it:
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
Mar 22, 2011 | Microwave Ovens
How to change from celcius to fahrenheit? How did get change by it's self?
Try the following. Cheers, Joseph
°F/°C CONVERTIBILITY - Press and hold SET TIME and
HOLD TEMP buttons until the temperature display is in
Celsius (°C). To display Fahrenheit (°F), repeat the pro-
cess. 5:30AM.)
Nov 23, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Measuring Tools & Sensors Logo
441 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
