Hello. You can unlock a Blackberry 8310 safer and easier using unique unlock code. You can get the unique unlock code for a Blackberry 8310 from ProUnlocking.com at affordable cost with an easy unlocking guide. Good luck.
SOURCE: Would like code to unlock blackberry 8310 so that I may travel
Your answer for unlocking cell | Mobile phones - SEE
http://www.unlocksellphones.com
SOURCE: blackberry curve 8310
if your phone is user password locked you can enter the WRONG password ten times and it will reset itself but this will also erase all data. if you need the unlock code so it can be used with other carriers like tmobile you can call att at 1800-331-0500 choose to speak to an operator and ask them if they can provide you with the unlock code you will need to have the imei # and they will help you for FREE.
SOURCE: blackberry 8310 unlocking
hi
dont worry you can get codes from official provider itself
they are the cheapest code providers and you relay on them too
Click Here
SOURCE: Free unlock code for blackberry 8310 from Rogers
It's a clear and fully detailed guide on how to unlock a BlackBerry Curve-8310 :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE : BLACKBERRYMEP.COM
SOURCE: need the unlock code for my black berry 8310
Unlock your Blackberry curve 8310 by using a Blackberry IMEI Unlock code, also called Blackberry MEP unlock code. Here is a link to get Unlock code for Blackberry within seconds.
Excellent customer and technical support, and you can pay using Paypal or credit card by phone.
Hope this helps!
Warning : Do not enter
any wrong unlock codes on your Blackberry Curve 8310 mobile phones. If
you enter over a certain amount of wrong unlock codes on your Blackberry
Curve 8310 mobile phone, your phone may get hard locked and sometimes
become unusable.
1 - Switch on your Blackberry Curve 8310 with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry Curve 8310 keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry Curve 8310 will now be unlocked.
