Kitchen Ranges Logo
G
Graham kinsella Posted on Jan 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am a gas age engineer,working on a rangemaster classic 90 gas cooker,when the electrics were connected the cooker ignitions keep on without calling for gas,have put a new spark generator on and now
Replaced spark generator
mbarre
Level 3:
  • Master 937 Answers
  • Posted on Jan 08, 2015
mbarre
Master
Level 3:
Answers
937
Questions
Helped
311210
Points
5626
Sounds like a bad control valve.
Duel fuel Rangemaster Classic 90 (10years old) No gas supply to front small burner on hob! all other burners working fine.
Hi Anita,
I am not shure, but do this cooker have already flame faillure device?
In that case I thnk this is the problem.
If not, it is a clogged nozzle.
You can remove that nozzle, that is under the burnercap, with a 7 mm wrench. Then clean it so you can see trough it and put it back.
They look like the ones in the link.
RANGEMASTER Oven Cooker Natural Gas to LPG Conversion Nozzle Kit A027639...
Have a nice weekend, Dik
Replace ignition button
Hello Angela,
does your cooker looks like this one?
Then one of the very small buttons should be for the ignition.
To replace that, you need to remove the control board, as they are screwed at the back.
So work for an engineer.
But I know a much easier way.
Clean your button with brake cleaner, or thinner or something like that.
Try to find the cheapest spray can with silverpaint.
Be shure that you have covered all the parts that you do not want to be sprayed and only spray that part of the button that needs to be silver.
Every one will tell you that you are an Expert.
Good luck with it, Dik
1helpful
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/Toledo90Gas.pdf
The manual for theToledo with both electric ovens can be found here:
http://www.rangemaster.co.uk/media/575792/toledo%2090%20dual%20fuel.pdf
The main product page for the toledo 90 can be found here:
http://www.rangemaster.co.uk/range-cooking/toledo-90.aspx
1helpful
Want to fit a new timer to our rangemaster 90 classic, got the part ready
Hi. If this is a ALL electric cooker then you can do the job yourself. If partly gas then you MUST have it done by a ALL GAS qualified engineer.
Its a fairly easy job but you will have to unscrew several screws on on the underside of the front panel and also on the rear of the appliance.
If you would like assistance then please phone me on 01733 307019
regards
Aardvark repairs
2answers
Ignition wont work, there is an electrical supply to the cooker
yes there will be a cooker switch located somewhere in the kitchen & from that there will be a supply to a cooker point witch is a white box that is no bigger than a single socket.
there should or should have been a 10mm heat resistant flex running from that to your cooker.
if there is a flex then your ignition mite run off a 3volt battery.check your manual if not then try this web site :
http://www.rangecookers.co.uk/installation-guide-content,MGQJD.aspx
Don't know what electricity supply is required
Emmet in luton: what fuse does a rangemaster 90 duel fuel need?
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
