Hi you can purchase network unlock code for your Blackberry 8520 curve mobile from online providers like UnBBLock.com for reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock the phone then freely use it with any GSM sim ...
Hello. you can get the accurate unlock code for your Blackberry 8520 Curve from Mobile-Unlocker.com at affordable cost with an easy unlocking guide. Good luck.
.................UNLOCKING INSTRUCTIONS.................
1 - Switch on your Blackberry 8520 Curve with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry 8520 Curve keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold ?ALT? key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry 8520 Curve will now be unlocked.
SOURCE: i need unlock code for my blackberry 8520 curve
How To Unlock a Blackberry Curve 8520
1. Turn on your Blackberry Curve 8520 phone with your current network/service provider’s SIM card.
2. Using the menu go to Settings Menu -> SIM card and press select.
3. While holding the SHIFT key, type mepd.
4. You should now see the five locking categories listed.
5. While holding the SHIFT KEY, type mep2.
6. Release the shift key.
7. You will now be prompted to enter the Network MEP code.
8. Enter the Unlock Code.
9. Enter Return/Enter.
10. Your Blackberry Curve 8520 phone should then be unlocked.
Now you should have yourself a fully unlocked Blackberry Curve 8520. Before you can use your newly unlocked phone on a new phone carrier’s network, you must buy a SIM card and order a voice plan with that carrier. If the steps above did not work on your Blackberry Curve 8520, do not try repeating as this could just permanently lock your mobile phone.
SOURCE: BlackBerry Curve 8520 Smartphone: when i turn on my blackberry curve 8520 it has a b...
just re install the blackberry operatind system software into ur fon from ur computer................and go on ....................or u can take off the battery and put it into again and press the return key when the red light goes off and till ur cell completly opens dont leave the return key..............it opens ur cell in safemode and u can deal with the error in safe mode
SOURCE: i need an unlocking code for blackberry curve 8520
Well if you are tied to a particular network all you have to do is call up the customer help line of the service provider and ask them for the unlocking code, which will be provided to you for a nominal amount of money.
You can also get the unlock code through online..........i will suggest the website http://www.blackberryunlockingcodes.com which is doing good service .....you can approach this website.
SOURCE: need free unlocking code for
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the websiteUnlocking.comwhich is doing good service .....you can approach this website.
