I am new to star gazing and really want to know what is in the skies above me at this time of year
SOURCE: LX200 EMC MEADE 8 INCH
By doing this trick--
Do a FAKE alignment-- (I assume that the scope is trained and has the proper date, time, and site)-- just push the buttons for the alignment stars that you cannot see. Then do a GOTO to a star that is in your field of view--- center the star and SYNC. Your gotos will now be OK in your limited field of view.
SOURCE: GoTo Problem
Be sure that the telescope is configured for EQ SOUTH mode to tell it is in the southern hemisphere. Once a star alignment is completed NEVER manually move the telescope. Use only the control panel to slew. Everytime the telescope is move by hand, the motors do not know it has been done, and assume it is still pointing at the old direction. Check the manual for setup.
Here: http://www.celestron.com/c3/images/files/downloads/NexStar_SLT_manual.pdf
SOURCE: How to use telescope at night?
Many people have the same problem-- with these small telescopes you are stuck with seeing only the moon, and several other planets, and maybe a few bright star clusters.
These are all TINY objects (except for the moon).... when you look through the telescope you are looking at a section of sky about the size of your fingertip held at arms length-- the scope must be pointed DIRECTLY at the object. Practice on the moon first-- and then try to find Saturn which is up in the sky right now-- it looks like a dim (slightly yellow) star.
Download a free star chart at www.skymaps.com ---
SOURCE: I have just bought my son a NG70CA telescope. Have
Try to locate a local Astronomy club and attend their star parties. Also download the free monthly star chart at:
www.skymaps.com Objects in the sky are tiny. Your scope must be pointed directly at them or you will not see them in the eyepiece. Make sure the finder scope is aligned with the main tube perfectly. Then use the finder scope to align the telescope.
This may also help you:
http://www.cloudynights.com/item.php?item_id=810
Testimonial: "Thanks for your help.not too sure what you mean by Make sure the finder scope is aligned with the main tube perfectly.am really new to this but thanks"
