Typically, I press 30sec button to use, and oven will automatically start cooking. Now when I press the button the timer starts counting down, but the oven doesn't come on. This was happening randomly, but is now happening more oft than not. Could this be a fuse or a sensor? If so can I fix?
Could be a bad door switch or a bad relay. With the door closed try gently pushing it up and down if at some point the unit fires up, one of the door switches is not making contact. As for the relays they are on the circuit board, but not replaceable unless you are very good at De-soldering. Also keep in mind microwave units have very high very deadly voltages stored in the capacitors 4000V that can easily kill so don't mess with them unless you know what you are doing!
