Televison & Video Logo
p
pamila g stacy Posted on Jan 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I check and see when there taking the money out of my bank acconnt
I HAVE ROKU THUR NETFLIX
JEM
Level 3:
  • Master 406 Answers
  • Posted on Feb 16, 2015
 JEM
Master
Level 3:
Answers
406
Questions
Helped
149158
Points
2858
Call them and / or look at your card billing statements
4answers
Will a roku work with netflix
Netflix Activation with Roku devices
  • Make sure that you enter Roku activate devices and also incorporated with the 5.1 audio options.
  • These 5.1 audio options are required for streaming of high quality contents.
  • So ensure your Roku device comes with these 5.1 audio options to enjoy high quality screening.
  • All the devices have Subtitles and captions as a default options.
  • Netflix avail users with Parental controls options and they can set their own Individual Profiles.
  • For Roku 1 model Go to Home screen > Select Netflix. You can visit channel store and your preferred Movies and TV shows are selected from there. Once you selected your preferences choose Netflix and add channel option is clicked to add your favourite shows.
  • In case of other Roku models, Go to Home screen > select Netflix. Go to channel streamed and then select preferred Movies and TV shows. Select the SignIn option from home screen activate Netflix in Roku to stream your preferred contents.
Signing out of Roku
Make sure that you enter Roku activate devices and navigate to Roku Home menu by pressing the home button. Select the Setting and choose Netflix settings from the menus. Select Deactivate the player from the Netflix account and chose the option yes now your Roku device will be deactivated.
tip
Roku, How To Setup a Roku Player
You want to try the Roku player so you can stream NetFlix to your TV over your home internet connection. It can be a bit of a hair pulling experience to set one up. So I'll try and make it as easy as it can be. First; Once you receive your player, and connect it to your TV. You need to get your new player on to your home network, be sure you have a router with wireless capability's. You will need to know the name of your home network, and you will need to know your WEB key or the pass key to secure your access into your home network. To do this, go to "Settings" (on the Roku menu) then scroll thru the menu until you see "Network", press network, look for your home network and press on it, then put in the WEB key to access your home network router. Remember after each step unplug the Roku for 10 to 20 seconds to set the memory.(may take more than 1 time with some players) NEXT; Go to www.Roku.com internet site and set up your account with them, they will need info on how to bill you if, you use a pay chanel. So they will need some bank account info, Or you can use PayPal. Next On the Roku "My Account" page, down at the right bottom of the page you will see the "Link Player" button, follow this to input your Link code, or go to http://owner.roku.com/link to input the code. Then go to the Roku menu screen and finish the setup with your Link Code. This will now activate your new Roku player. Next you will want to go to NetFlix and set up an account with them. Same thing here, they need bank account info to bill you, if you stay past the free demo time limit. Now go back to your TV, Roku menu and scroll thru the menu to press on NetFlix, here you will go thru the Menu to get another link code. This time it will come on the TV, Roku menu to go back and put that code in your NetFlix account to activate your Roku player with NetFlix. Now in the process of all this, you may have to unplug your Roku player after each link code to set it into memory. This causes a lot of folks to have some trouble as they do not, "Turn Off" the Roku after they put in the network key, the Roku link code, then again after they put in the NetFlix link code. One last bit of help. Do not create a large Instant Queue on your NetFlix account over 50. This causes problems with the memory usage in the Roku player, and It can keep NetFlix from loading. Hope this helps FixYa up.
Roku problems
No, no cost to use the Roku device. Well, apart from the purchase from the store :)
The only cost involved would come from services (or games) that are available on the Roku device. For example, if you want to watch Netflix, you would need to have a Netflix account which costs a little money, But Crackle (which similar to Netflix) is free to use. There are many free channels available, Nasa channel, music channels etc.
hope that help.
Netflix member log in
you need router wich support openvpn check your router model number with dd-wrt.com and see if you can change the frimware and get openvpn software on it , if this compatible then you need vpn account you can grab from http://www.overplay.net/#a_aid=vpnprovider
May 02, 2014 • Netflix
1helpful
How to hook up to roku
See this tip I have posted here on this site. >>> Setting Up A Roku <<< and read this, You want to try the Roku player so you can stream NetFlix to your TV over your home internet connection. It can be a bit of a hair pulling experience to set one up. So I'll try and make it as easy as it can be. First; Once you receive your player, and connect it to your TV. You need to get your new player on to your home network, be sure you have a router with wireless capability's. You will need to know the name of your home network, and you will need to know your WEB key or the pass key to secure your access into your home network. To do this, go to "Settings" (on the Roku menu) then scroll thru the menu until you see "Network", press network, look for your home network and press on it, then put in the WEB key to access your home network router. Remember after each step unplug the Roku for 10 to 20 seconds to set the memory.(may take more than 1 time with some players) NEXT; Go to Roku's internet site and set up your account with them, they will need info on how to bill you if need be. So they will need some bank account info Or you can use PayPal. They need this info in case you order a pay for movie or swap to a paid channel. Next On the Roku "My Account" page, down at the right bottom of the page you will see the "Link Player" button, follow this to receive your Link code, write this code down and go to your TV, Roku menu screen and put in the Link Code. This will now activate your new Roku player. Next you will want to go to NetFlix and set up an account with them. Same thing here, they need bank account info to bill you, if you stay past the free demo time limit. Now go back to your TV, Roku menu and scroll thru the menu to press on NetFlix, here you will go thru the Menu to get another link code. This time it will come on the TV, Roku menu to go back and put that code in your NetFlix account to activate your Roku player with NetFlix. Now in the process of all this you may have to unplug your Roku player after each link code to set it into memory. This causes a lot of folks trouble as they do not, "Turn Off" the Roku after they put in the network key, the Roku link code, then again after they put in the NetFlix link code. One last bit of help. Do not create a large Instant Queue on your NetFlix account. This causes problems with the memory usage in the Roku player, and It can keep NetFlix from loading.
2helpful
2answers
Cannot get into netflix, when checking they tell me to check out the Roku box?
If your Roku is working properly, and will not connect to Netflix. Access your Netflix account through the internet on your home computer. Check the size of your instant que and if over 50 entry's, start deleting your que. The Roku can not handle over 50.
1helpful
Trying to hook up roku wireless player, need pass word?
Top Roku Televison & Video Experts
vince
Paul Carew
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
