Question about Carrier Heating & Cooling
Led indicator light on carrier weathermaker infinity says open fuse
    Problem Solver:
  • 15 Answers
Ok there is a small 3 amp or 5 amp fuse on the board inside the furnace. this is like an automotive fuse in a car
Posted on Jul 08, 2009
6ya staff
SOURCE:
What do I do if red LED light stays on and my furnace (Carrier WeatherMaker 9200), does not start.
turn power off for 5 min to reset and check thermostat wiring the red wire should be connecting to the white try a jumper at the furnace
Sep 12, 2014 | Heating & Cooling
Code 24 on carrier weathermaker 8000ts
Turn power off to unit. Open air handler and take a picture of the low voltage (tstat) wires and where they are landed. Remove all thermostat wires from control board. Then replace the 5 amp fuse that is likely on the board. Fuse likely looks like one for a car (blade style). Put a jumper (small piece of wire) from the R terminal to the G terminal and turn power back on to unit. This should bring on the indoor blower. Let me know how that goes!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 12, 2017 | Heating & Cooling
Carrier Weathermaker 8000...no LED lights on, but breaker is ok. Anything I can check before paying a ton for a service man?
This <a href="www.curthel.com">carrier</a>
has everything to quickly and safely deliver your <a href="www.curthel.com">car</a>.
Nov 04, 2013 | Carrier XHB123D X/Y Series Heat/Cool Air...
Will not ignite. LED Code 31
Could well be the inducer motor Google carrier 31fault code there are 3 video's on this on u tube
Jan 15, 2018 | Carrier Weathermaker 8000 Gas Furnace 125k...
Carrier Weathermaker 8000 led stays on constant, blower works and i have power to the controller. no power at the ignitor/gas valve.
Check your thermostat level +29 and mode in Heat. If still problem, Check power
RV. Please write if your problem not solved with above solution. Thanks.
Dec 11, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
CARRIER INFINITY WEATHERMAKER WHERE IS THE RESTART SWITCH
Carrier Infinity systems, do not have a manual reset switch. It will have an automatic reset depending on the failure.
I would first, turn off the breaker to the indoor and outdoor units. Wait about 5 mins and turn the breakers back on. Doing this will reset the Control Board in the system. The system itself, is probably locked out.
This should get the system to come back on, However, you may have the problem come back and lock out the system again.
If this happens again, i would advise calling a Carrier dealer with Infinity systems to test it.
Hope this helps
Brian
Nov 28, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 stopped working.
look on the inside of the panel an you will find the diagnostic indications blinks there that will tell you what is going on
May 23, 2010 | Heating & Cooling
Carrier Weathermaker won't stay running
Is this a gas furnace if so is it high efficient if so is there an led light on the furnace blinking a code usually seen through a window at the furnace. is the thermostat battery operated if so is it a new battery and are the aif filters new. These would be my first steps to check hope this helps
Dec 21, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
324 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
