Washing Machines Logo
Geoff Middleton Posted on Jan 05, 2015
Can you please advise me how to turn off the auto rotation on a Dyson CR01, as I am getting the F18 fault,
I have tried cutting out my mother in laws tongue but this has not cured the F18 fault, although I feel much better, Geoff
  • Lorraine Rice-Mahony
    Lorraine Rice-Mahony Feb 25, 2015
    HI Geoff, did you get an answer to this?
keno
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 05, 2015
keno
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
96
Points
Wow ,OK check it to out,first of all dyson is built for auto magic rotation when ready to vaccumm.if u disconnect it u stop your roller brush for good.u might as well walk around then to vaccumm with a little hand held.sry.
How can I repair a leak from underneath the coin trap of my Dyson Washing Machine?
Hi there, it's Jack at Dyson.
I can recommend a couple of checks that should help. Firstly, it's important to make sure the coin trap window is correctly rotated into position (one and a half turns clockwise) ensuring the childproof tab clicks into place. Check the plug is also pushed fully back into place: http://www.dyson.co.uk/support/cr01/cro1-flowcheck-white/maintaining-your-dyson-machine/check-the-coin-trap-step-1
It's also a good idea to check the seal within the coin trap is correctly in position, and hasn't been damaged in any way.
Unfortunately if the coin trap or surrounding components have been damaged, we've been unable to provide spares or servicing for CR01 or CR02 washing machines since December 2012. If you'd like to discuss this with the Dyson UK Customer Helpline, you're welcome to call us on 0800 298 0298.
How to fix f18 fault
The f18 code that pops up in these models is related to the "contra-rotating" mode unique to this line. This mode is very tough on the gears and drum and they end up binding. The only "real" fix is a new drum assembly, which dyson has run out of for service parts. You can run the washer without using the contra-rotate mode and the unit will not act up. Other than replacing a no longer available part, some owners have found that by washing some oil-soaked articles (such as shop rags or towels drenched in motor oil), the offending parts binding issue can be lubricated away for quite some time. When the f18 error returns, they just wash some more oil into the problem area to make it disappear again.
Check out the facebook page for more info than you will need.
93867830652471/">Facebook logo facebook.com/groups/293867830652471/
1helpful
2answers
Dyson cr01 fault F4
Hi Sue, it's Jack at Dyson.
An F4 fault code means 'inner door opening'. Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
If you would like to discuss your concerns further with one of our experts, you can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
4helpful
It would appear door has been locked via child
press and hold the minimum iron button on the front panel until the child lock light goes out then you should be able to use the machine as normal
Dyson CR01 - How to clear F8 - Overfilling : Turn Off Water?
Don't panic, simply call our Helpline free on 0800 298 0298. One of our advisors will be able to assist you!
Kind regards
Darran
Dyson Customer Service
2helpful
2answers
This morning got F11 fault on Dyson CR01 front loading machine, before that drum wouldnt turn and making grinding noises. Dyson have already removed the contra rotating cycle on this machine, is this...
may be the rear bearing has gone,my con/rota packed in and i took the drum out cleaned ,replaced, greesed, and alls well , if it is the rear bearing DON"T let them tell you its scrap if you are good at diy you can take the bearing out and fit new one, bit of a time comsumeing job
F11 fault code
Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
I am sure it would help you to resolve the issue.
God Bless.
5helpful
How to repair a F 11 fault on a DYSON CR01 flow check
To Clear F11 Code after a power cut.
3, Power on
Thanks for using Fixya.
7helpful
3, Power on
Top Dyson Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
