Seems to be problem with the contacts from the wand.
SOURCE: kenmore vacum wand power cord
http://www.vacsew.com/vacuum-cleaners/kenmore-vacuum-parts.html/
Try here
SOURCE: central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
SOURCE: Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
SOURCE: I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
SOURCE: How do you open the power head to remove the
Greetings,
Thank you so much for that clarification, I know the exact model of Kenmore that you have now. This model is actually made by Panasonic for Sears who puts the Kenmore name on it. I wasn't able to located the Sears owners manual, but I did find a Panasonic model that uses the same power nozzle as yours does. I will also explain how to access the roller brush below, and if you'd like to see diagrams of how to do it, you may visit the link below to the Panasonic owners manual. Start at page 46, then go back to page 40.
http://service.us.panasonic.com/OPERMANPDF/MCCG973-MUL.pdf
In order to access the roller brush on this model, here's what you need to do. Underneath of the headlight cover, there are two screws that need to removed first. In order to get to these screws, simply push on both sides of the headlight cover, and lift it straight up while pushing both sides. After the headlight cover has been removed, you'll be able to visibly see the two screws that need to be unscrewed (phillips head screw driver). Remove these two screws next.
After the screws have been removed, turn the power head upside. If you look at both the left and the right sides, you'll see a little indentation on each side. All you need to do is put a flat head screwdriver in these indentations, and pry up on both sides. This will remove the top housing. Once you have top housing removed, you'll see there's one more cover that goes over the roller brush. There are two tabs on both sides behind the roller brush. If you squeeze these two tabs, you can now remove the white colored housing that covers the brush, and have full access to the brush.
I hope that this helps you remove the twine from your beater bar. If you found this repair helpful, please be sure to rate it by clicking the thumbs up icons in the top right hand corner. If you have any other questions about how to repair this, please feel free to request a clarification, or add a comment to the repair, and I'll be more then happy to help you.
Thanks very much,
Chris Jones
GoVacuum
