My vcr does not take the tape. i put it in and it does not fully go in. Then when i press play it says there is no cassette.What should i do?
Take the cover off & have a look at the cassette carriage, it may have came out of alignment, ie it is taking the tape at an angle or there maybe a fault with the carriage motor switch. when you put the tape in so far the carraige activates a switch which starts the loading motor to draw the tape in. It could be there is no supply voltage to this switch or the loading motor might be faulty, this is why the VCR says there is no tape as the tape has not been able to load into the machine. A repair centre should be able to fix this fault quite easily.
